Piston Soak with Berryman B12 (116)
I am trying to do a piston soak in the cylinders using Berryman B12 (116) and my all of my pistons can’t seem to hold the solvent longer than 5 minutes . All the B12 solvent immediately drained into the crankcase after I poured through the spark plug holes.
Does this mean my piston rings aren’t clogged or stuck closed?
i saw YouTube and the liquid should be stay inside the cylinder at least 6 hours or more for the solvent to dissolve the carbon on top of the piston.
Any inputs?
Any inputs?
Any inputs?
Any inputs?
Looks like you have to do 3 pairs of two cylinders, 24 hours at a time at TDC, for a 6 cylinder engine?
He sums it up starting at @37:50.
Similar to what the guy on the video advocated for the V6 engine.
Do you have a bore scope camera to make the 'checking' easy?
nemoD
1G RDX (2007-2012)
Sep 1, 2024 01:54 PM
bg2128506
Feb 6, 2019 09:15 PM
VictorTL
Oct 23, 2018 06:18 PM
Arcticcl9
Jan 19, 2005 12:15 PM
