PIAA Hyperwhite turn signal bulbs
Will these work in place of the yellowish turn signal bulbs now that I have my headlights cleared? Will they blink when the turn signal is hit if I just plug them in and nothing else? I just want to make sure I don't have to do any special wiring or anything else because I am not up on the whole wiring, relay stuff.
The link is here for the bulb:
http://www.gen5alive.com/store/index...roducts_id=352
LEDs, on the other hand, if not wired with a resistor, flash at a faster rate than normal bulbs.
Stand For Something
Yeah those will work just fine, I had them in for like a month with no problems. I changed to switchbacks tho.
Trew - please tell me that your avatar isn't real, I almost just died laughing.
I would so jump on the switchbacks, but I also don't want to play with any resistors.
it's worth the 20 minutes it will take you to install them. You don't have to splice any wires either. I used 2 (supplied) wire taps to tap into the turn signal wire and ground. That was it. The resistor screwed in with a single self-tapping screw on the vertical brace near the quarter panels. I didn't even have to extend the resistor wire. I wish I had thought to take a picture of my install. It really only took 20 minutes.
I wish you took some pix But I'll do it... Because right now I look like a xmas tree... 6000k HID, stock amber turn signals, and Hoen Yellow Fogs.... So Ice blueish white, amber and very yellow...yay...
09-17-2015 09:01 PM
Greengecko
09-16-2015 08:19 PM
