Paint and Windshield
Old Jan 11, 2005 | 03:44 PM
cosmos13's Avatar
I have a very small chip in the front windshield. Size is about pen point. Any suggestion?
I also have a paint chip . Very small and when i put my finger over it i can hardly feel the chip. Again any suggestions?
Thank you for your time.
Cosmos
Old Jan 11, 2005 | 04:08 PM
rets's Avatar
Moderator Alumnus
Paint chip could be covered by touch-up paint.
As for the windshield, do you call your insurance or the window specialist? They would have easy way to fix that "hole" if that really bothers you. IMO.
Old Jan 11, 2005 | 04:35 PM
SouthernBoy's Avatar
Registered Member
If you're as anal as me, you'll stay off of interstates or similar highways, take back roads and residential areas, and try to avoid roads with a lot of trucks.
Old Jan 11, 2005 | 04:48 PM
djmikel's Avatar
djmikel
Most autoglass shops in Colorado can repair a chip in about 10 min. They drill a hole through the glass and use some kind of mixture to fill it. It is heated and becomes damn near invisible.
If you don't repair those chips here they will soon turn into an extensive crack across the windshield.
Old Jan 11, 2005 | 04:59 PM
cosmos13's Avatar
Thanks for the info about glass. But can someone give me more info on Paint chip. How to prepare, apply and etc would be helpful.
Thank you,
Cosmos
Old Jan 11, 2005 | 05:27 PM
Acuraluvr's Avatar
Spinnin them beats
touch up paint is veryuneven, would not trust it; i used a rubbing compouns on a chip and a scratch and worked greats, be sure 2 wax to make it almost invisible
Old Jan 12, 2005 | 10:46 AM
cosmos13's Avatar
"touch up paint is veryuneven, would not trust it; i used a rubbing compouns on a chip and a scratch and worked greats, be sure 2 wax to make it almost invisible"
Can anyone else give more advise? Should i use rubbing compounds instead of touch up paint?
Cosmos
Old Jan 12, 2005 | 11:16 AM
Novice's Avatar
http://www.bettercarcare.com/articles.php?articleId=27
TheMuffinMan
Jun 2, 2022 07:11 AM
Jul 16, 2017 07:33 AM
bluetl04
Aug 16, 2016 02:49 PM
detailersdomain
Wash & Wax
Oct 9, 2015 10:13 PM
rhdune16
Sep 28, 2015 11:31 AM
