Oxidizing the Gas
Oxidizing the Gas
Have they started Oxidizing the gas now since it is getting cold. My 6MT 04 is starting to get pretty crappy gas mileage, and it just started to happen this week.
The gasoline is oxygenated, not oxidized
There have been some previous posts in regards to this. Generally the gas mileage will go down, but only slightly. Here is a great link explaining the process if anyone is interested.
http://www.chevron.com/prodserv/fuel...ne/default.asp
Registered Member
No, it is not nationwide. When I lived in God-foresaken Arlington, VA, the fuel over there was oxygenated. At the time, I had my 1988 Mustang LX 302CID. I noted a 14% drop in fuel economy with the attendant increase in power.
The pumps at the stations in Prince William Country (where I now live) do not have the sticker about oxygenating the fuel between Nov 1 and the end of February. At least, not in my part of the county.
Registered Member
To fla-tls;
I used to wonder the same thing. However, with today's cars, this is pretty much an exercise in the ridiculous. Engines have never been cleaner burning and it's getting better all the time. In 1996, my Ford Contour SE produced fewer contaminants with the engine running than my 1966 SS 396/360 L34 Chevelle did with the engine off. And that was 10 model years ago! The EPA is living in the past and needs to wake up and smell the exhaust.
Gratis dictum
Not a Blowhole
Originally Posted by fla-tls
Ummm - what's the point of "cleaner burning fuel" if you have to use 10% more of it? ![Screwy](https://acurazine.com/forums/images/smilies/screwy.gif)
It ios called politics, and the politics of power.
Oxygenates are generally alcohols, and ADM and other large corporate entities are huge suppliers of ethanol for fuel, and likely some of the oxygenates used in the "clean" fuels. ADM was a huge contributor to both of Bill Clinton's campaigns, and has donated a ton to Congress, and through expensive lobbying efforts.
Politicians love alcohols - it makes them look green to the voting constituencies who are big on styole over substance in this matter - mostly soccer moms, and unmarried females.
And few of the voters are smart enough to figure it out, as you did, that it is a big scam.
There are also side-effects of oxygenated fuel that technically-inclined folks like me know all too well from what we have seen in the field:
1) Oxygenates produce very stubborn, tarry deposits on fuel injectors, intake valves, and even the tops of the pistons. Unless removed, they can affect the spray pattern, leaning to a less clean burn, less fuel economy per unit of measure, and the driveability problems some experience. Valve depoists abosrb fuel, causing a false read by the O2 sensors which must enrich the mixture - more fuel consumed and more emissions.
2) California futher went the route of MTBE - not only was it a fraud, but it has been shown to have caused pollution of lakes and streams, far beyond the effects of simple "noirmal" fuels.
The simple fact is that the alcohols used in oxygentaed gasoline produce less thermal output when burned - it does not take a genius to understand that it will therefore take more fuel to cover the same distance, and since emissions are a function of fuel consumed over time, some, if not most, of the "benefits" of the oxygenated fuel are in reality "funny money".
We are the ones who get ripped - we pay more in fuel costs, and either pay someone to clean our fuel systems, or have to put in expensive aftermarket cleaners to do the job. (See my RR Journal on fuel additives).
Originally Posted by JackSprat01
Is there any way to know where this fuel is sold? What cities or states?
RR gave a great synopsis of the politics and technical aspects of oxygenated gas.
Not a Blowhole
I know Richmond has it - I drive to powhatan County to get non-reformulated gas in the winter, when the fuel is at its worst.
Adding Sta-Bil is a good idea for those of you who reduce your miles in the Winter - and wait until the fuels are switched over - many discount places will get "leftover" summer gas, whose volatility differs from what is needed when it gets cold.
![Woot](https://acurazine.com/forums/images/smilies/woot.gif)
Yeah, in these parts (Pacific NW), they are required by law to display a large sticker in a conspicuous location, saying if and how the fuel is oxygenated. I'm also glad I live across the river in Washington. Vancouver is the largest suburb of Portland, (larger than every other city in Oregon actually), but doesn't require oxygenated gas, like the tri-county area in Oregon. I always go out of my way to always fill up with non-oxygenated gas. Around here, it seems 76 and Exxon always have oxygenated gas, even if they aren't required too.
Gratis dictum
Interesting comment. I usually buy Union 76 or Chevron and have never used oxygenated fuel. I guess us folks on the north side of the Columbia River are lucky.
Originally Posted by insmanblue
That is interesting. I just figured that all the states used oxygenated gas in the winter time. I travel to Vancouver about twice a week now, and will make it a point to fuel up there. What stations have you found that do not carry the oxygenated gas in Vancouver?
But anyways, from what I've seen, Shell has never had oxygenated gas. I have seen the chevron on Mill Plain use oxygenated gas, but I've never seen any of the other Chevrons with it. Every 76 station I see oxygenates their gas, as does Exxon. The Fred Meyer on 164th also doesn't have oxygenated gas. In fact, I actually found their gas to be strangely good. I've been getting gas their, and been getting better mileage than when I fill up at Shell or Chevron.
Don't forget that you have to fill the gas yourself in Washington, I've seen many cars with
![HaHa](https://acurazine.com/forums/images/smilies/haha.gif)
I'm not sure which part of vancouver you are going through, as I don't spend much time on the part of Vancouver by I-5. (I live closer to I-205).
Oregon plates sit in their cars for a very long time, and even honk at the cashier, or storm into the minimart. It's ok, I've also seen washingtonians go to oregon, and try to pump their own gas, only to have a gas attendent come screaming out of the minimart.
