Oil question
2006 Anthracite Metallic
Oil question
My dealor recommends every 3750 miles. I'm about 3,800 and the useful life is at 60%. Acura.com has no maintenance information. From reading the the various forums, I take it I'll get a message when oil gets to 15% which should be around 7K. My question is, should one wait that long for the first change.
I did mine at 3500K with 60% life in my RL. I will never keep oil in my car for 10K miles. I did same for mine 2-nd car, 04 TL and 60K miles later no problems at all. www.bobistheoilguy.com
Gratis dictum
I did my first change at 4000 miles. Thereafter, generally went by the MID, but no longer intervals than 5000 miles. Havoline 5W-20 oil with a Purolater filter would be good choices.
I didn't do mine in my '05 until the minder said time out. It was about 6 months as well.
Originally Posted by Phesto
wheres Road Rage when you need him
Changing it per the MID is fine (won't hurt the engine), but its probably a good idea to change it before 5000 for the first time to remove the increased wear metals from break-in.
MID will base the interval for other items off of the determined drain intervals for oil. But some items, such as transmission fluid, I would suggest changing more frequently, such as every 15,000 miles, given how "hard" Honda transmissions are on fluid and their troublesome reliability history.
BoricuaTL
04-08-2016 01:08 PM
IIDXholic
10-08-2015 07:53 AM
