Oil question
Old Mar 26, 2006 | 05:48 PM
reelfun1's Avatar
2006 Anthracite Metallic
Oil question
My dealor recommends every 3750 miles. I'm about 3,800 and the useful life is at 60%. Acura.com has no maintenance information. From reading the the various forums, I take it I'll get a message when oil gets to 15% which should be around 7K. My question is, should one wait that long for the first change.
Old Mar 26, 2006 | 06:13 PM
Phesto's Avatar
some say the oil from the factory has an additive that helps during the break in period,I'd say maybe wait..............But use your better judgement
Old Mar 26, 2006 | 06:15 PM
SouthernBoy's Avatar
Registered Member
Yes there is an additive. No, you should probably change it before 4000 miles regardless of what your MID tells you.
Old Mar 26, 2006 | 06:22 PM
slawek65's Avatar
I did mine at 3500K with 60% life in my RL. I will never keep oil in my car for 10K miles. I did same for mine 2-nd car, 04 TL and 60K miles later no problems at all. www.bobistheoilguy.com
Old Mar 26, 2006 | 06:26 PM
Phesto's Avatar
wheres Road Rage when you need him
Old Mar 26, 2006 | 07:38 PM
Repecat's Avatar
Gratis dictum
I did my first change at 4000 miles. Thereafter, generally went by the MID, but no longer intervals than 5000 miles. Havoline 5W-20 oil with a Purolater filter would be good choices.
Old Mar 26, 2006 | 08:03 PM
jupitersolo's Avatar
nnInn
I didn't do mine in my '05 until the minder said time out. It was about 6 months as well.
Old Mar 26, 2006 | 08:26 PM
whatjones911's Avatar
Does the MID only tell you when it is at 15%?? What else will it tell you to do except changing the oil?
Old Mar 26, 2006 | 11:48 PM
SodaLuvr's Avatar
He's on vacation from this forum since a few members gave him a hard time, but also because of the repetitiveness of technical topics on this forum.
Changing it per the MID is fine (won't hurt the engine), but its probably a good idea to change it before 5000 for the first time to remove the increased wear metals from break-in.
MID will base the interval for other items off of the determined drain intervals for oil. But some items, such as transmission fluid, I would suggest changing more frequently, such as every 15,000 miles, given how "hard" Honda transmissions are on fluid and their troublesome reliability history.
BoricuaTL
Apr 8, 2016 01:08 PM
IIDXholic
Oct 8, 2015 07:53 AM
atsx1313
Sep 22, 2015 09:04 PM
VolkingTL
Sep 16, 2015 09:10 PM
datadr
Sep 12, 2015 09:12 PM
