The Official "Does This Fit My Car?" Thread
#321
94 DC4 RS LSV/Turbo
it will be slightly off, but not enough to not match...
lets just put it this way, from teh factory the wdp bumper is wdp yet it doesn't match the car... the difference between ssm and asm is way less than that, so it is almost not visible
#322
Good Thread (tires)
I have an 04 Tl, non-navi
came with 235/17/45
want to put on 245/17/45
10 mm wider......... like the thread says...
came with 235/17/45
#325
94 DC4 RS LSV/Turbo
I have wider wheels, and no rubbing, but its near stock
You won't rub unless ur slammed (3" drop), at which point the tire will touch the fender
#333
94 DC4 RS LSV/Turbo
if you'd like to run 235, your fronts will be ok, but the rear will require you to buy a rear camber kit, and run -2 degree and also have 0 degree toe and also roll the fenders in the rear
you cannot roll the fenders in the front (if you do you will have some visible damage to the front body line curve where the fender meets the bumper)
#335
B A N N E D
I'm thinking about buying these wheels for my car. Will they fit?
http://cgi.ebay.com/ebaymotors/09-Ac...oto#ht_930wt_0
#336
94 DC4 RS LSV/Turbo
The bolt pattern is 5x120 and the offset if +55
You will have to get a wheel adapter in order to allow fitment
Pm me if you need a place to order the wheel adapters from
The wheel adapters you will require are as follows
5x114.3 to 5x120, with a thickness between 10mm to 20mm
Should you decide to pursue these wheels, you will surely be the one and only 3rd gen sporting them
Good luck
Good luck
#340
94 DC4 RS LSV/Turbo
progress has different part #'s but it is all the same
#343
Team Anthracite President
Year: 2004 TL
Trim: Base
Item would like verified: 2008 Type S rear bumper and 4 pipe exhaust system.
My car was recently hit in the rear would like to replace with an 2009 Type S bumper and 4 way exhaust pipes, will it fit?
Michael
Trim: Base
Michael
#344
Now that I have read 9 pages, let me ask in a different manor.
Seems 08+ Type S rear bumper covers will fit 2004-07TL's.
Can I use my stock exhaust or must I purchase the 4 pipe exhaust to make it all work (I'd like to put the bumper cover on then find a used 08+ exhaust).
Thought I somewhere bumper cover fits, but needs a little cutting? Can you explain what needs to be cut, and by how much.
Lastly, is the 4 pipe system a direct fit to 04 - 07 models or does that need to modified and is a bolt in or weld in?
Thank you,
Michael
Thank you,
Michael
#345
94 DC4 RS LSV/Turbo
ok here is the lowdown
04-08 base is 1 tip on each side
07-08 type s is dual tip on each side
04-08 base bumper fits 07-08 type s (same applies to the 04-08 base skirt on an 07-08 type s)
07-08 type s bumper fits 04-08 base (same applies to the 07-08 type s skirt on an 04-08 base)
as for the exhaust, the 04-08 base exhaust fits the type s no problem
the 07-08 type s exhaust when installed on the 04-08 base will require either an 07-08 type s rear bumper, or an 07-08 type s rear skirt (which will require some cutting)
cutting: very minimal... pm me if you need pics of exactly what needs to be trimmed
#347
Year: 2004
Trim: Base 6MT
Color: ABP
I need to replace the front bumper cover, which has some cosmetic damage. Will the '07-'08 base bumper fit? What about the '07-'08 type S. Any mods required, or will it snap in?
Trim: Base 6MT
Color: ABP
#349
94 DC4 RS LSV/Turbo
it fits 100% but all of the grille pieces will need to be swapped out for either the flat grey from the 07-08 base or the black chrome from the 07-08 s
#350
More Than Meets The Eye
Currently Own:
07' Type-S, 5AT, Brembos
I want to purchase 04 A-Spec Gunmetal 18x8.5 +45 Offset
Will these fit without any problems and clear the brakes?
#351
I have another question (assuming they fit without any issues)...
Will I lose my TPMS? Is there anyway around this?
And lastly is there a way to shut off the light that will be a constanty eye sore?
Thanks!
Thanks!
#352
will the speedo and tach from a 08 type s fit my 04 5at? Would i need to make any changes?
also... Instead of doing a full bbk i was thinking just doing new brembo calipers for all 4, they do not make specific for tl what car should i get them for and what do i need to change? (6mt rotors are nice but i want the rears to look the same like porsche has same fron and rear)...thanks
#354
Posting this here too .. sorry and thanks stillhere153
Wheel Make/Model: Platinum Gripp
Wheel Size (**X**):18x8
Wheel Offset (+**):+40
If lowered (amount): none
Transmission (Manual or Auto):MT
Year/Trim (04-07, Base or Type S):04 base
Width/Sidewall-Diameter (***/**-**):245/40-18
Edit: will they fit?
#355
94 DC4 RS LSV/Turbo
for brakes pm excelerate
for gauge cluster... it should fit, but you will have to cut and splice for the mid screen
#356
94 DC4 RS LSV/Turbo
it'll need a 5 or 6mm spacer
#358
Former Whyner
Year: 2005
Trim: Navi
Color: SILVER
Item you would like fitment verified: I got one for ya. The clock display on the 8th gen civic is blue (non-si) and red (si). Can that blue display be transplanted into our boring gray to match everything else blue? it looks the same.
http://us.autos1.yimg.com/img.autos....12_346x270.jpg
Trim: Navi
Color: SILVER
#360
94 DC4 RS LSV/Turbo
Year: 2005
Trim: Navi
Color: SILVER
Trim: Navi
Color: SILVER
do you know how to solder... if so it'll fit straight custom retrofit
