O2 sensor brand?
O2 sensor brand?
Hey all, I ended up with a worn out primary O2 sensor, replaced it, found out the replacement was defective, and had them send me a new one, it was defective as well...just slower to come up with codes. My fault for deciding to go with a cheap brand, so they refunded it and I'm moving on. What brands do you trust to replace the bank 1 sensor 1 sensor with? I'd rather save some money, but if it's just going to be defective...I don't want to waste more of my time. What brands would be dependable for this?
Thanks!
Thanks!
Bosch are decent.
From the how-tos section.
"It is stated on the forums to stay away from the Bosch generic sensors, as these don't work well with the engine management on the TL."
https://acurazine.com/how-tos/a/acur...-sensor-423885
Latent car nut
OEM never disappoints.
Latent car nut
So I changed out my A/F sensor on Bank 2 about a year ago.
Bosch is a good brand and it's cheaper, upon inspection, looked A1.
Well.. a year later, it's tripping balls. Now my precat efficiency might be poor, but first inspection looked good.
Going to remove the J-pipe and do a light test. Right now it looks like the sensor went to shit.
Buy OE
Buy OE
^ I got put on game by Gus btw
Gus
Gus
Much appreciated all, Denso I go. Relatedly, I see some people suggest when doing an upstream sensor, replacing both is a good idea, should I go ahead and and do that or not worry about it? I'm at 169k and they're the originals, but I am trying to be cautious of my budget.
Latent car nut
If I do decide to replace both, which I think I will, anyone have any links to videos of replacing that one, or is that the one right next to the hood latch? I can't find videos and guides on it for the 3rd generation TL. Relatedly, how important is it to make sure it's tightened to a specific torque over just getting a nice solid tightening done on it?
Also, this appears to be the other upstream sensor if I'm getting all the part numbers lined up right, correct? https://www.walmart.com/ip/DENSO-Oxy...9179#read-more
From what I can tell (bloody hard topic to find info on outside of the bank 1 sensor 1), the Denso upstream sensor works for both the sensor 1 and 2 locations, correct? Trying to tell if simply ordering 2 of the below are what I need #234-5010.
https://www.walmart.com/ip/DENSO-Oxy...-5010/34173670
Anyone have videos on how to deal with it? Looks like once I have it jacked up it should be easy to deal with, but I'd love to have some reference.
mcdanjw
03-24-2004 07:53 AM
NighthawkBlack
10-12-2000 10:57 PM
