Not sure what it could be?
Old Dec 30, 2021 | 01:13 PM
Jjvv81's Avatar
Just recently changed all plugs and coils and car sometimes has a misfire or at least feels like a misfire also car makes a rod knock sound sometimes in reverse or when parked in a spot at a slight slant
File Type: mov
Old Dec 30, 2021 | 01:17 PM
You used OEM brand designated plugs for your model?
Old Dec 30, 2021 | 01:29 PM
Jjvv81's Avatar
Yes used all oem parts
Old Dec 30, 2021 | 01:32 PM
Jjvv81's Avatar
I used all ngk plugs and coils
Old Dec 30, 2021 | 03:56 PM
Midnight Mystery's Avatar
Null and proud of it
What fuel are you running?
Old Dec 30, 2021 | 04:15 PM
Jjvv81's Avatar
Regular unleaded
Old Dec 30, 2021 | 04:16 PM
Jjvv81's Avatar
In the am when I cold start it runs rough I warm it up to running temp and when I reverse it makes that sound
Old Dec 30, 2021 | 05:28 PM
Pair of TLs's Avatar
Is it possible you have water in your gas?
Dump in a bottle of HEET.
Also, buy better gas.
Old Dec 30, 2021 | 05:33 PM
Jjvv81's Avatar
Ok I’ll try that thanks!
Old Dec 31, 2021 | 10:53 PM
Superunknown's Avatar
Car takes premium.
Old Jan 1, 2022 | 04:45 PM
Jjvv81's Avatar
It crazy I’ve owned the car for about 3 years only put regular in it and never had a problem until I did the last tune up about 3 months ago. Thanks for all the input will definitely change octane
Old Jan 2, 2022 | 11:28 AM
Jackass's Avatar
Lack of premium is unlikely to be the culprit unless you have just been using crap fuel in general. If you insist on using 87 octane, at least make sure it is top-tier rated to make sure there are enough detergents to help keep things clean. Give 91+ a shot for a tank or two and see if it helps...but my guess is it won't.
Old Jan 2, 2022 | 10:58 PM
So the problem began 3 months ago when you did a tune up?
Check OED for HINT.
Old Jan 3, 2022 | 02:11 AM
Jjvv81's Avatar
I did the tune up in June 2021 but in November it gave misfire codes so I had a mechanic look at it turned out to be a dead coil. Changed the coil and about 3 weeks later same issue. So I changed all coils again car worked fine for about a week and now this issue but no codes or lights. At first is would only happen after a cold start and then after bringing up to temp I’d put it in reverse the car would make that sound and sometimes while waiting at a light it would feel like misfires but still no codes.
Old Jan 3, 2022 | 06:28 AM
619rcr's Avatar
Have you done a compression check?
Old Jan 3, 2022 | 03:46 PM
Jjvv81's Avatar
I have done a compression test every cylinder came out good
Old Jan 3, 2022 | 09:43 PM
619rcr's Avatar
Find it odd that it happens at a slant. Motor mounts are all good? Have you listened to different parts of the motor with a mechanic's stethoscope?
Old Jan 3, 2022 | 10:17 PM
Jjvv81's Avatar
The motor mounts have cracks so they do need to be replaced but today I backed it up in
my driveway and I heard the noise from the drivers side rear. Around the tire. So I’m not sure if it’s my rear end or maybe something else with the suspension
2001CLCoupeLife
Nov 9, 2017 10:02 AM
Mr.Tea
Aug 16, 2014 02:03 PM
808 Fifty-State
Jan 2, 2011 04:15 PM
IfAcuraWasAgirl...
May 5, 2010 04:03 PM
type-s09
Dec 22, 2006 12:35 AM
