Noob again, another question...
https://acurazine.com/forums/3g-tl-2004-2008-93/auto-trans-fluid-change-method-761145/
https://acurazine.com/forums/3g-tl-2004-2008-93/rr-journals-atf-drain-refill-3g-garage-c-012-a-556044/
You drain 3 quarts of your transmission fluid and refill 3 new quarts of fluid.. 3 times.
Thanks Arthur, but...
So, when you drain the fluid will only 3 qts drain at a time? I am assuming, procedure is,
1. drain 3 qts
2. add 3 qts.
3. drive but for how long
repeat and then repeat again?
1. drain 3 qts
2. add 3 qts.
quick cliff note version.
-drain 3.
-replace all bolts
-add 3
-drive around for a little bit or cycle your car on jack stands
-then immediately or a week later
-drain 3
-replace all bolts
-add 3
-drain 3
-replace all bolts
-add 3
-Complete
GKinColo08TL (01-17-2012)
Please check the 3G Service Department before you click 'new thread.' Thanks.
P1zzaman (01-17-2012)
ggesq (01-18-2012)
