Nokya fog light bulbs
Carfreak
Hey guys i just installed a new lightbulb for my 05 NBP fog. I put in a NOKYA 80 watts Arctic Purple 8500K Stage 2. u guys should change out ur stock for one of these. THEY LOOK GREAT. I'll put some pics up when i get the chance. I got them from EBAY for cheap. They give u a choice of color and temperature too. There's Arctic Purple, Cosmic White, and Arctic White. Make sure u get the Stage 2 80 Watts if u get the Stage 1 it's only 55 watts.. it's not bright enough
Here's the link
http://shop.ebay.com/?_from=R40&_trk...All-Categories
Here's the link
My Garage not
1 Post
nokya are the best aftermarket fogs. i've tried a few different brands and either the fit is bad or the light output isn't as good as nokya. wish i'd known that before i wasted $100 on a few other crap brands.
King of NYC
WAIT!!! I advise you to really take those bulbs out! Stage I is what is recommended for our cars and for good reason. Stage II 80 watts is too much! They draw too much for the wiring to handle and burn hot. I know the risk is more with 100 watt bulbs but even with 80 the risks are there. I wouldn't recommend 10 watts more than OEM (65watts) to be on the safe side.
With 100 watts, I have seen people melt headlights, reflectors lose their reflective coating, harnesses melting, (that burnt plastic smell!) melted wiring and even underhood fires! Dangerous and costly mistakes to make.
If you really want to do 80 watts. (I did this safely on a car long ago) the least you should do is wire in a relay and separate in-line fuse. Just had to put a warning out there for you.
BxTrini_TL (11-08-2013)
KoolKatz..
+10^^^
Received 6,470 Likes
Guys, Rocky is absolutely right. Here's my fogs...
Which is better (your personal opinion), purple or yellow?
More a performance question, than aesthetics... My WAG is that yellow cuts through mist/rain/fog better than purple, but wanted to hear from others' experiences.
Correct-H8 bulbs for the fogs and 9006's for the DRL's (2007/2008's)
hey i was wondering if someone could help me out.... i'm a little confused. I want to get these fog lights to match my stock xenons on my 07 TL-S..
NOKYA Arctic White Pro Halogen H8 (Stage II)
12V55W
High Wattage
7,000K
Manufactory Part #: H8
First off... will these be a good match to the stock xenons? and second, are these ok for my car? they're only rated at 55W which i'm almost postive should be ok.. thanks.
12V55W
High Wattage
7,000K
Mike, that's what I have in my fogs. I really like them-they are a big improvement over the OEM bulbs. The 12 volt/55 watts are fine!
Stay Out Of the Left Lane
Received 1,241 Likes
Where are you ordering these from? Anyone have a link? Looking to do the same with my TL-S. Thanks
I will search eBay for the ones recommended above.
Same seller has the H8 for $19.98. Just concerned the say headlight on the packaging.
OState-9005's are correct. That was a typo on my part. I apologize for the confusion.
Buddy, I'm sorry about that-I didn't proof my response before I posted. Didn't mean to make your heart stop for a second!!!! By the way, they're a bitch to get to (on the drivers side). The passenger side is easy, but we had to take out the battery to get to the DRL on the driver side. But the 2nd time we replaced the bulbs, we just took out the venting that is between the battery and the headlight assembly-that worked OK (without taking out the battery). It's just a cramped space.
Buddy, you don't need to take out the battery for the foglights and the turn signals. You can get to both of those from the wheel wells. You only need to remove the battery for the DRL's.
04 A-TL 6MT SSM/E N/Navi
Vic has a good point-HID's are nice, but I wanted to go for the simple fix.
