No Power Outlets
Old Jun 14, 2007 | 10:21 PM
Acuraluvr's Avatar
Spinnin them beats
No Power Outlets
went on a recent road trip lately and brought a radar detector and a power inverter.
found out the power outlets dont work... could this just simply be a fuse?
there are on other problems to note of
Old Jun 15, 2007 | 12:57 AM
csmeance's Avatar
what other problems are you experienceing? It could be 3 things.
1. Blown Fuse
2. Disconnected wires (this happens sometime when a tech takes apart the car and rushes to put it back together
3. Wires burnt, there must have been an overload and the wire burned up
Old Jun 15, 2007 | 05:13 PM
Xx06SickspdTlxX's Avatar
06 TL 6spd. Navi/A-spec
I would check the acc. fuses in the drivers underdash fuse box first, you probably overloaded the circuit and blew a fuse. If that isnt it i would consider the steps said above.
Old Jun 16, 2007 | 12:56 AM
Acuraluvr's Avatar
Spinnin them beats
blown fuse... thats what we were expecting...
easy replacement right? autozone?
Old Jun 16, 2007 | 06:32 AM
Well for now you could probably use the spare fuses from the underhood fuse box.
Old Jun 16, 2007 | 04:50 PM
csmeance's Avatar
yup, autzone should have them. I think its a 15 amp fuse...make sure it is a mini one and put it in at autozone so you can return it incase it doesn't fit...
Old Jun 17, 2007 | 09:11 AM
Acuraluvr's Avatar
Spinnin them beats
??? there are spare fuses under there?
but yea, 15 amp, got one at autozone
thanks guys
Old Jun 17, 2007 | 11:01 AM
Yes the car has spare fuses 1 of each, they are located in the under hood fuse box, just look under the cover and it will tell you which ones are the spares.
Old Jun 17, 2007 | 01:59 PM
Trackruner228's Avatar
If you ever drop a penny in those things I know it will blow the fuse you havent done that have you?
Acura604
20
Aug 5, 2017 12:55 AM
spudweb
May 22, 2016 02:39 PM
knight rider
Mar 4, 2016 08:59 AM
95oRANGEcRUSH
Sep 25, 2015 12:50 PM
TL14
Sep 24, 2015 04:37 PM
