New TL Owner Questions
Old May 19, 2012 | 11:16 AM
Jesse729's Avatar
I just picked up a 2007 TL type S 6MT a couple of weeks ago. I have a few small issues and I am wondering if they are normal.
1. Just curious but has anyone had either of their side view mirrors get a discolored look at the bottom like water got underneath? I saw this on 2 other TL's I test drove and thought it was strange. I will probably replace the mirror.
2. I was happy to see that the rear brakes have a second drum brake for the parking brake unfortunately when I set the brake I can rock the car almost like an automatic in Park. There is like 3 or 4 inches of play with the parking brake. Any ideas? Anyone's TL like this?
3. I have a really rough idle around 1100 to 1500 RPMs and I have seen a lot of people talk about the cold idle roughness but this will happen if the car has completely warmed up. Around 1200 RPMs it is really rough. The car has 75k on it and I was going to start with the plugs they are original any other ideas? Is this normal? Should I just live with it?
Old May 19, 2012 | 11:26 AM
Undying Dreams's Avatar
1) That means the heaters were left on, you'll need new glass.
2) You can adjust the handbrake on the brake itself and adjust how hard you have to pull the lever for it to lock.
3) Usually it will run rough if it's cold, after it warms up it will be fine. You might want to get it looked at.
And welcome to the forums!
Old May 19, 2012 | 04:21 PM
Turbonut's Avatar
When RPM is raised to @1200 it won't run smooth, perfectly normal, same as fast idle when cold.
Old May 21, 2012 | 11:17 AM
LoveMyTL-S's Avatar
Congrats Welcome to AZ! Check out the 3G garage for tons of info. Also register your TL at www.myacura.com in the USA or https://www.myacura.acura.ca/ in Canada. Save your Navi and Radio codes there. Check for any recalls your TL may need.
You may also want to post here:
https://acurazine.com/forums/3g-tl-2004-2008-93/3g-tl-owners-sign-564449/
Old May 21, 2012 | 12:33 PM
BrownBuck's Avatar
BrownBuck
Really? Doesn't our heated glass turn off automaticly after a while? i have no idea since i haven't used it just..just asking.
Old May 21, 2012 | 12:57 PM
CLtotheTL32's Avatar
Nope, it stays on until you push the button off.
Old May 21, 2012 | 01:19 PM
BrownBuck's Avatar
BrownBuck
damn that's weird. so now i have 2 features i liked in toyotas...this and the trip odometer! meh Acura>Toyota still tho
Old May 21, 2012 | 01:21 PM
mY sLOW UA6's Avatar
We have a trip odometer....actually 2
Old May 21, 2012 | 03:47 PM
LoveMyTL-S's Avatar
I wanna say the seat header in low stays on and in high goes on and off, then back on. It's alternates.
Old May 21, 2012 | 03:54 PM
Yeah the heated mirrors will stay on, be sure to keep an eye on them. I use them for about 5-10 mins to get the morning dew off them, then I turn them off.
Old May 21, 2012 | 04:10 PM
MEKO's Avatar
I hate the ones that turn of by itself...well here in Boston.
In the mornings 8-10 F, you remote start the car, you go in after 15-20 min...mirrors are still frozon.
vaughanml2
Nov 1, 2021 10:16 AM
IIDXholic
Oct 8, 2015 07:53 AM
V-tecAc
Sep 21, 2015 09:25 AM
datadr
Sep 12, 2015 09:12 PM
Steven Vitek
ILX
Sep 10, 2015 07:29 AM
