new o4 Tl Owner with 2 easy questions
1. Is the VSA button suppose to have a backlight? Mine I cannot see in the dark
2. ALso is the trunk button suppose to have a backlight. Can never find it at night time.
I have an early production 04 TL
thanks
thanks
a lot of the times those lights go out for whatever reason
when i got mine the drivers side heat warmer light was out
seems very common but easy to fix and under warranty
Terminex
Yes they should light up
This is a common item. the lighted buttons in the TL 04 - 07 have an actual bulb inside each switch. the buld is EASY for the delare to replace. you simply pop out the switch from the dash, and then you will see the bulb on as a blue circle on the side. you can use a coin or a knife to rotate it a quarter turn and then it will fall out. there are actually small filament bulbs, they are NOT LEDs. they are a small bulb with a blue rubber cover to give the slightly muted lite you see from the front.
I confrimed this on an 04.
Terminex
Why?
Originally Posted by 1chiroTL
thanks once again. off to the dealer to get charged 50 bux for .35 bulbs and 49.65 in labor.....
snorf
11-04-2019 06:44 AM
mugen_kid
11-13-2015 10:38 PM
