New Glo Sills
Originally Posted by ensley696
Where can we get these?
it's very time consuming to tape off the lettering and checkers. for more detailed info, send me email.
cheers
Originally Posted by cTLgo
great idea, but what about the durability of the paint?
doesn't the paint need some light to "charge" this glow?
I'm figuring it does, so how long are you leaving the paint in light to get the glow in the above pic?
I'm getting at the point that this is really cool, but that sill is never exposed to light for any length of time. And I imagine that to get a bright glow like the above pic, the paint would need to be exposed to light for some significant length of time.
Props on the job, though! I curious as to your reply.
Vinyl???
I have access to a vinyl cutter and was thinking of making some vinyl decals in various colors to lay into those same cutouts he used paint for... That way if they get scratched or damaged, just replace them... Or if you get a hankerin' for a new color, you can just slap it in...
Should look the same, minus the glow... Unless they make glow in the dark vinyl...
On the CVAJS job... LOOKS FANTASTIC man... (Points AWARDED!) I'd suspect it needs subjected to light to glow as well, although if you could use the same stuff that's on watch faces and night sites for guns (tritium, I believe...) it would glow by itself... Bearing in mind the stuff is slightly radioactive however, I don't think you can pick that up at the craft store!!!
Did you determine a price on that????
I assume since you are just painting it, you can do it for any car assuming the sills aren't very complicated and the taping isn't too difficult???
Are you planning on doing a mail order deal with them or doing a core swap???
there has got to be an easier way, maybe making a stencil and re-using it for each sill. or just spraying the sill without a stencil, then wiping the excess off while wet and whatever is recessed will stay unwiped. just some suggesttions, but it looks hot!
after full charge (10 minute charge from 1000 lux), output is 25914mcd/sq.m (on LS-100 light meter)
note: A cyalume glow stick like those at festivals glows at about 20,000mcd/sq.m
the brightness does drop-off over time, from hour 9 to 12 output is 5mcd/sq.m
this is glow paint folks, uses no resources from the car and requires no wiring, no bulbs/leds to burn out, etc.
it's a neat effect.
if demand becomes high enough then i'll outsource the stencil making (mask needs to be tight on the surface, and positioning must be 100% right-on or else it wont look correct).
the paint is solvent based, so it wont be nice to try and wipe off excess (paint is also expensive, so there will be no waste).
yes, it's just paint, can be done to just about anything. i use automotive masking vinyl tapes (they curve easy around bends and hold tight to the surface).
if new part is wanted i would need to get parts from dealer, or you send me yours (no core deals).
Originally Posted by AcidHorse
The more I look at it the more I WANT it!
Would it still glow as bright as it does in the pic 3 years from now? Even after a full charge?
Guys Product Looks Hot, But this is not what I am looking to do. My Plates are cut now and all I am waiting for is the graphic plate to show you the final Mock Setup. My Plates will have wires and will look and light up just like a Mercedes. These are great but again not the look I want for mine.
Will keep you all updated.
Dave
Sorry for such a slow process but we have started this project from scratch
Dave
He is right...
the green paint does glow the longest (12+ hours)
here is how the other colors stock up against the green.
http://glowinc.com/SearchResult.aspx?CategoryID=2
this stuff is $$$ as hell
Originally Posted by GRK_TL
He is right...
Originally Posted by NFLblitze1
lol that one deserves rep points....
but this paint wears off after 12 hours? dosn't that make it kinda pointless..
no, it stops glowing after 12 hours until it gets more light
Dave
Dave
however, (IMHO) glow paints give me more artistic freedom. i have not really "used" my airbrush, now is the time i will.
hope to see your lighted sills soon.
cheers
Originally Posted by dips009
Hi,
How much paint will I need to do all 4 door sills? A pint??
thnx
thnx
Does anyone know if there is any blue glow in the dark paint that perfectly matches the blue color of the lights inside the tl? I have found some "Pure Blue" Glow in the Dark paint online but I wanted to know that the colors would be very close before i spent my money on this expensive stuff.
http://www.readysetglo.com/Glow_Pain...info.asp?id=15
Originally Posted by jobes
Okay. So to recharge I now need to keep my doors open. Do I do this on a sunny day going downtown or will my blue LED lights in my doors charge them?
Originally Posted by cvajs
LED's will not work. glow paints need UV. this is indeed the "pitfall" to glow paints. there should be enough ambient light if the car is outside during the day. tints that block UV need more time than without tint. every mod has a price to pay.
I agree with you guys that it looks great. but who really wants to charge their door sills? and that blue one only goes for 2 hrs. its just a hassle for some cool lighting, when u can connect some simple wires. Im still with supercomputers with his project.
Looks very nice! From the numbers on the paint supplier's website (above), it doesn't seem like that intense glow will last for more than a few minutes though. According to that site, after one minute, the brightness is reduced from 25914mcd/m2 to 3560mcd/m2. And after ten minutes, you're down to 590mcd/m2. So yes, you'll have some glow, but it won't necessarily be very bright. It may be worth the trade off, however, just so you can get the OEM sill look. I'd rather go blue though if the intensity isn't going to be there anyway.
even a dim glow from the sill at night still looks rather cool.
cheers
