need tune up advice
need tune up advice
hello.
i have 2004 TL and it about 63k on it. i own it about one year and a half. i want to do some tune up to the car and have couple question.
first question:
i know first thing is the spark plugs need to be replace. and what you guys recomand for what kind of spark plugs that is working the best. and what is the gap?
second question:
coolen need to flush and how should i do it. should run some water to the radiator hose to get all the gunk out from the engine. or just drain out the old coolen and replace it.
and what else to the tune up i need?
first question:
second question:
use honda coolant or `approved for acura` coolant- its different than others
50/50 premix or make your own with distilled water from the grocery store
NGK Iridium spark plugs at kragen or local parts store- 50 bucks for the set of 6 is normal price
Ask the parts man for the correct ones for your car- they look it up
Gap is preset on the ngk and can be damamged if you mess with it
coolant procedure is in the owner book- there is a drain on the engine that has to be opened too
need a freee owner book?
https://techinfo.honda.com/rjanisis/...01_OMANUAL.asp
click cars year then model
read the Garage section on here for tips on spark plug change
do seafoam cleaning thru gas tank and intake manifold vac port a week before the plug change
Makes it nice and clean inside!
AZ Community Team
Received 7,771 Likes
Depending on whether previous maint has been done, check and/or replace:
- Engine Air filter
- Cabin Air filter
- Brake Fluid
- Transmission Fluid
Engine air filter and cabin air filter should have been done around 30k and 60k (depending on MID and driving conditions).
Brake fluid should be done every 3 years (according to the Owners Manual)
Trans fluid should have been done at 60k if under harsh conditions; by the MID otherwise. BUT many around here don't trust the Honda trannys and will do Trans Fluid about every 30k miles (some more often).
- Engine Air filter
- Cabin Air filter
- Brake Fluid
Cabin air filter done on-3-01-2009.
CAI filter been replace a month ago i replace it once a year.
atf done about 3 months ago.
break fluid not yet.
thanks.
thanks.
MrHeeltoe
20
02-23-2023 01:54 PM
soupi
14
11-15-2015 11:15 AM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
