Need some Torque Numbers
New shoes on my
Hello everyone,
Sorry if this is posted in the wrong place. I need some torque numbers for some installs that I'm doing and I was hoping someone with a service guid would be so kind as to look these up for me...or....let me know if there is a place that I can look up info of this nature.
So I'm looking for:
Throttle body to plenum bolts. I think someone mentioned 16lbs?
Bolts throughout the exhaust system. I think I heard 40lbs? (more specifically, cat to j-pipe, cat to exhaust system)
Crankshaft bolt holding the pulley. I think I heard 180lbs.
Also, everyone mentioned some spot that you can stick a strong screw driver in to keep the pulley from spinning when tightening the bolt. Can anyone help describe that, or perhaps provide me a photo?
Much thanks in advance.
So I'm looking for:
Do it like the rest of the population. Just tighten the bolts till they are tight......
If you are gonna lose sleep doing it that way here you go...
cat to jpipe-40ftlbs, jpipe to 2nd cat/bpipe 25 ftlbs, bpipe to mufflers 40ftlbs, tb to plenum 16ftlbs, and the crank.... proper torque is a procedure of base torque to 47ftlbs and then using a angle gauge and marking the crank and bolt, turn 60 degrees. I have worked on Acuras for a long as time and have never torqued any of these bolts. The only two things I have ever torqued (off the top of my head) are cylinder head bolts, rods and mains, camshaft caps, and lug nuts.
New shoes on my
Thanks Racinghart. A buddy of mine gave me a torque wrench, so I figured I'd use it, but it doesn't appear to be that important. The main thing I was concerned about was overtightening and stripping out the plenum, as that would be a costly mistake and I've been known to overtighten things before. Thanks again.
emailnatec
29
Sep 28, 2018 04:27 PM
jterp7
3G MDX (2014-2020)
Feb 3, 2016 08:34 PM
