Need My lights clear !!!!!
Old Jun 4, 2005 | 12:02 AM
DayLight324's Avatar
I live in central New Jersey and I was wondering if anybody has a good spot where I can get my headlights cleared. If anybody knows anywhere in New Jersey or New York that could do a professional job and for a good price please help. Thanks
Old Jun 4, 2005 | 01:04 AM
crazymjb's Avatar
Your garage. But besides that I don't know of any places, sure their are some though.
Old Jun 4, 2005 | 09:29 AM
NBP04TL4ME's Avatar
Stay Out Of the Left Lane
There is a board member who goes by Mr. . He clears everything. Look him up and/or search for cleared lights and you should be all set.
Here is one:
https://acurazine.com/forums/showthr...learing+Lights
Old Jun 4, 2005 | 09:53 AM
Teh Jatt's Avatar
The Oracle of Acurazine!
there is a shop in Glendale, CA called Rego Sport, you can probably mail the headlights to them.
Old Jun 4, 2005 | 10:12 AM
astro's Avatar
Community Architect
robb m.
Removing Bumper
1. Remove screw in front of each front tire.
2. Remove plastic pins from the underside of bumper.
3. Remover 10MM Bolts from underside of bumper.
4. Remove plastic clips on top of bumper.
5. Remove screws on top of bumper.
6. Unplug foglights.
7. Remove bumper.
Removing Headlights
1. Remove Bumper
2. Remove bolts from the side of the headlight housing.
3. Remove two bolts under the headlight housings.
4. Unplug connections.
5. Remove headlights.
Clear Lights
1. Remove Headlights
2. Place headlights on a wet towel inside of an oven. Heat oven to 225 degrees. (Do not preheat)
3. After 20-25 minutes remove headlights from oven.
4. Seperate headlights by hand starting from the inner corner.
5. Allow to cool for 10 minutes. Using a razor, trim excess silicone from the inside of the lens cover. Do not remove silicone from the black portion of the housing where the sealant channel is, you will be reusing it.
6. Remove thw two screws that hold the chrome housing to the lens cover.
7. You may now pop out the amber reflector by pushing a CLEAN screwdriver or any utensil for that matter through the hole fpr the parking light.
8. Reattach the chrome portion of the housing to the clear lens.
9. Place lens and black housing back in the oven at 225 degrees for 10 minutes. Do not reassemble yet.
10. After the stock sealent has softened remove both pieces from the oven.
11. Add a small, fresh bead of silicon to the sealant channel on the black portion of the headlight housing.
12. Beginning from the outer side of the headlight, reattach the lens portion of the housing to the black portion.
14. Tighten lens to the black housing in each corner using bar clamps.
15. Allow 24 hours for silicone to cure.
16. Cover holes with duct tape. Test for leaks in steamy bathroom.
17. Put back on car.
taken from Soopa's Instructions
Old Jun 4, 2005 | 01:14 PM
crazymjb's Avatar
Love tep 16. I never would have thought to test for leaks before putting em back in. I will keep that in mind. But I am a visual learner, so again, project pics would be greatly appreciated. When the assembly is put in the over, is the bulb and projector etc all on there? I am kinda confused.
Old Jun 5, 2005 | 03:47 PM
Bitium's Avatar
Retired MOD
I used to clear lights. The instrutions are good, but I would use a heat gun instead of the oven, because they are some parts the heat might damage. Like for example, there are breathers in the headlight unit that are made of cotton material that will burn if put in the oven. DO NOT removed the original silicon, since you will not find any silicon that does a better job, with that said, do not add any other silicon. If you do it right, you can reuse the original silicon with no problems. ALWAYS start to open the headlight with the inner bottom corner. Is not hard, but be patience and careful.
Old Jun 5, 2005 | 04:09 PM
ndx2's Avatar
6MT & LSD
i also remember someone using a hair dryer, instead of putting the headlights in the oven. it might be the easiest way.
mada51589
Jan 9, 2025 04:40 PM
PortlandRL
Sep 14, 2015 12:01 PM
ellisd03tls
Sep 8, 2015 04:17 PM
voigt
Sep 2, 2015 10:44 PM
