Need instruction help
Old Jun 23, 2006 | 05:47 PM
Jesstzn's Avatar
How do I remove the bezel thats around the shift leaver. I need to clean under it .. spilled pop .. also whats the little plug for in the pix and how is it removed?
Old Jun 23, 2006 | 05:57 PM
johnny--2k's Avatar
My Daily Driver
The little plug is the shift-lock release, so if you need to get the car out of park and it wont start, you remove that plug and stick your key in the slot, then you can move the shiftlever without the car running.
As for the shifter bezel, you will most likely need to remove the entire center console as it is probably fixed, and the center console sits around it.
edit: the bezel around the shifter, with the plug in it, should snap out, then the console sits over the acutal shifter bezel with the markings on it. Thats how it was on the 2G tl's!
Hope that helps. Just be careful removing the outer bezel. It's fragile.
Old Jun 23, 2006 | 07:38 PM
Ron A's Avatar
Administrator
Here's a little more information and some pictures, from the 3G Garage
F-052: DIY: how to remove the 2 aluminum strips in the center console
https://acurazine.com/forums/showthread.php?t=90964
rcs86
Aug 2, 2016 06:52 PM
gatrhumpy
19
Dec 31, 2015 04:22 PM
thegipper
Sep 28, 2015 01:01 PM
mshipon
2G CL Problems & Fixes
Sep 28, 2015 12:14 PM
08_UA7_Gr33k
Sep 27, 2015 12:42 PM
