Need help with TSB, unable to see it
My TL is about go out of warranty and I have one issue I have yet to resolve.
It is the power steering whining noise that comes around when I startup the car in humid/cold weather. The sound goes away after driving for awhile but it is LOUD!
There is a TSB on it but I cant get to it, even using the method that is posted in the TSB thread.
This is the TSB thread
https://acurazine.com/forums/3g-tl-2004-2008-93/3g-tl-technical-service-bulletins-tsbs-3g-garage-j-016-a-613659/
And I trying to get to TSB 07-060: Power Steering Moans or Whines
I would like to be able to see and print the page to show my local dealership.
Any help is appreciated
did you not read this:
IMPORTANT NOTICE
UPDATED 6 DECEMBER 2010
We have regained our access. Follow these instructions.
1. Open this link .
2. Select the entries as follows:
Acura
2010
TL
Then click on "submit vehicle information"
3. Open any one of the listings.
4. You can now open the below listed links.
IMPORTANT NOTICE
1. Open this link .
Acura
2010
TL
He's trying to help. Maybe a little appreciation for the effort is more in order?
Following the access instructions posted, I can open TBS 07-060 no problem.
If you're able to open other TSB's (i.e. you properly followed the access instructions), then there is some other issue that is effecting you but not everyone else.
that was helpful.
I'm telling you my experience...I tried once without the instructions, and the 2nd time I did the instructions and the PDF downloaded for me.
its something on your user end. not faulting you for not doing the instructions, but maybe your computer.
Might be easier:
http://www.aboutacura.com/2007/12/ts...e-is-cold.html
If you are using firefox and you open up the TSB before doing the workaround it will have the same result where if you open that specific tsb even after doing the workaround it still will give access denied (or what ever that error message is).
At that point either do a cache clear or use IE or Chrome.
tallyrlx
3G RLX Audio, Bluetooth, Electronics & Navigation
Feb 26, 2016 03:44 PM
