need help tranny fluid
Old Jun 19, 2008 | 03:37 PM
dea7hr0w's Avatar
i cant find where the fill plug is for a 2004 acura tl for the tranny any have any pictures of can tell me wehre it is and what the description of what the bolt looks like? i see bolt but it looks like it needs a socket wrentch insert, but im not sure..
Old Jun 19, 2008 | 03:55 PM
TeknoKing's Avatar
Welcome to AZ!
Check this thread out https://acurazine.com/forums/ramblings-12/anybody-good-xp-89064/
Peace
Old Jun 19, 2008 | 04:16 PM
dea7hr0w's Avatar
this is for an auto =(
dea7hr0w's Avatar
that post was for an auto...=(
Old Jun 19, 2008 | 07:25 PM
01tl4tl's Avatar
it depends if you have the external oil jet kit installed- what you will see
- that was the recall install part that goes on top of the transmission
check if you had that done if it was needed- went from 99 thru some 04s
http://owners.acura.com/registration...erstepone.aspx
need you VIN and then look in recalls section for more info
Later trans have a large headed bolt with ATF stamped on it for the fill plug- on top of trans
Are you changing the fluid or is it leaking- low.???
The drain plug is underneath the trans at the rear part - a regular ratchet fits in the square cut into it, it says ATF above it too.
the engine oil says OIL above its drain ~ what a smart car!!!
SidhuSaaB
May 30, 2020 12:40 AM
LeVeL
Oct 18, 2015 04:19 PM
lanechanger
Oct 13, 2015 10:56 AM
xsilverhawkx
Oct 5, 2015 11:00 AM
ROSSARONIE
Sep 22, 2015 11:46 AM
