Need help installing Hamsar DRL module
Old Jul 25, 2008 | 07:53 PM
off_boost's Avatar
Hey, I just bought this hamsar unit to activate my drl's, but I have no clue how to go about these dumb instructions, its a little too universal. Anyway I have the Hamsar 45040 unit and only works and full power.
This is the unit :
Its 6 wires that are badly identified, as follow :
-Green : Wrap around spark plug wire
-White : Low beam
-Orange : High beam
-red : 12v
-black : ground
-yellow : to parking brake light
Anyways, I have no clue what to do with the green wire since tl have coil packs and you cant wrap it around that. I dont know if its a ignition sense wire no clue. All I want is for the non-HID lamps to light up at all time and to turn off when the HID's turn on, can anyone help me with that thanks
Old Jul 25, 2008 | 08:03 PM
jptl04's Avatar
Bone stock tl-s
check out this thread https://acurazine.com/forums/showthr...ghlight=module
the wiring might be similar.
hope this helps.
Old Jul 25, 2008 | 08:23 PM
rockyfeller's Avatar
King of NYC
There is a DRL wiring DIY in the garage. Translate your wires to that DesingTech wiring instructions, it should work the same way.
Old Jul 25, 2008 | 11:20 PM
1Clean_TL's Avatar
I believe the green wire is not needed, i did the deisntech drl, and i remember there was an extra not needed wire, and I ran the yellow to the windshield wiper motor as explained in the DIY
Rachel Lu
Sep 27, 2015 09:53 AM
Sep 17, 2015 09:01 PM
TxRzrBk
Sep 17, 2015 01:07 PM
spiel08
Sep 7, 2015 08:19 PM
Fadij
Sep 2, 2015 08:31 PM
