Need help finding this bolt
Im going to have to call the dealer bc I cant find them anywhere. Yes there are 2 of them.
If you look in the service manual in the section for the oil pan, it says these 2 bolts are 10x1.25mm but no length
If you check the service manual in the section for removing the transmission, it says these 2 bolts are 12x1.25mm but no length.
WTF
WTF
![](http://www.acuraautomotiveparts.org/acura/jsp/mws/catimgs/14sep401_e06.png)
Part #17 ? This is the closest thing that I can find.
Look in the sub-component section called "ALTERNATOR BRACKET" (click here)
Regarding the diameter fitting in the hole. The pic with your finger looks correct. I think a 12mm would be too snug. It in normal for Honda to have large holes. There are probably pilot pins in the case used for proper alignment. The bolts normally are not meant to provide alignment.
cycdaniel
12-17-2019 10:58 AM
darksky
09-05-2015 03:11 AM
