Need Coolant Temerature Sensor and some other stuff...
Can someone confirm the part numbers for my acura tl 2005 AT
Coolant Temperature Sensor ?
3rd and 4th gear pressure switches and gaskets... i saw some different numbers so im not sure anymore...
thanx a lot
thanx a lot
Here is my take on what you need to order. Above is a pic of my order to do the trans switches on my 2006. I checked that your 2005 has the same part numbers. Also below are the part numbers for the water temp sensor and related o-ring.
28600-RAY-003 x1 SWITCH ASSY., AT OIL PRESSURE (TEXAS INSTRUMENTS)
28610-RAY-003 x1 SWITCH ASSY., AT OIL PRESSURE (TEXAS INSTRUMENTS)
90471-PW7-A00 x2 GASKET (10MM)
37870-PNA-003 x1 SENSOR ASSY., WATER TEMPERATURE (KEIHIN)
91307-PNA-003 x1 O-RING (9.5X1.9)
BukvaMan (11-28-2011)
Username 0
2G TSX Performance Parts & Modifications
23
09-28-2015 09:09 AM
