My wheel fell off literally
So I am driving down the highway going about 40 mph when i hear this shudder noise and then hear a boom and I am thinking oh shi*t. I notice my car is not level and I look out my window and I see my front left wheel roll down the highway.
My freakin wheel just flew off my car, and my car is sliding on the front rotor. I fortunately dont get hurt and traffic was very lite.
Well a tire place that installed my new wheels 10 days ago I think is responsible and I have been talking to them. I will spare their name for right now, because as of right now they look like they are going to pay for everything. They have even setup a loaner for me and this incident only happened 3 hours ago and are in the process of confirming the estimate of the body shop I took it to. The company sells alot of tires i will tell you that.. And i have RJ's on my car, and I am so lucky the wheel didnt get mashed up by flying down the road.
man, its very scary to loose a wheel while driving
The damage... damaged rotor, front left panel bowed up above the wheel well when the tire popped out, alignment, possible suspension work, control arm, knuckle, etc...
Wow definitely sucks. What I always do after I leave those tire shops is to loose the bolts and torque them all to 80. Sometimes those guys are in a hurry and forget. But at least your ok!
The Tire place didn't torque the wheel right, too tight or loose I guess. One stud was broken, but the rest were still there. The lugs completely stripped off the studs and probably flew like bullets..
I got a cell phone pic, let me upload it. I dont know how good the picture is though..
Got your mom in
That some crazy shit. Do you know exactly what caused it to fall off? If the rotor was still on the car that means the lugs were'nt tightened, and even if they were loose the ride would have been uncomfortable and it wouldnt have taken 10 days for the wheel to finally buck.
Dam. thats a brain teaser. Glad you're ok though and i hope everything works out.
ouch, sorry to hear that, that is like my worst fear. Everytime someone else touches my wheels I HAVE to check to make sure they are tight. I saw this happen to someone once and it was BAD! I hope you have gook luck getting the wheel shop to cover everything and thank god you were not hurt! This could have been a lot worse...
Let us know what happens and pics please
I have know idea what exactly caused it to happen. I just know I had all new tires put on my RJ's ten days ago. I didnt drive the car all week either since I was out of town. The car just started to shudder and the steering wheel shook back and forth violently and then boom!
http://i172.photobucket.com/albums/w...5f511b7402.jpg
That whole panel above the wheel well is bowed out too. I will have more pictures, the body shop is taking some. Its going to be a few days though.
PB.. that's insane.. that happened to my friends while traveling in Bolivia.. unbelievable.. at least you're okay.
With your past clutch issue this is just another pita! .. I can't believe you didn't blow your stack on these nimrods.
Whats a LSD? I know majofo, I have had a couple of bad months with my car. The clutch and now this, if everything works out ok though it will all be paid for by someone else..
Limited Slip Diff
Being an Acha Bacha in
Have them compensate you! I would try to milk the BBK Rotora. That's the least they can do to compensate for putting you and your family's life in danger! Fixing your car is not compensation, because they HAVE TO do that, since they fucked up! If they won't do that, tell them to give it to you at their cost and free install. I swear if that happened to me, I would turn their shop upside down! Simply unacceptable!
I have car ADD
yes, check LSD, check your suspension, check ALL your bearings, axles, cv joints, brembo rotors, dust shield, knuckles... you name it, id demand it was checked... dont let them through some new studs on and call it a day.... the wheels are the most improtant part of the car, any damage near them can lead to danger down the road
if they refuse to repair/replace or check the other stuff out, let them know that $2000 in parts now, is better than a $5 million dollar lawsuit when it happens again... and somebody gets hurt
Oderint dum metuant.
I saw some lady on the side of the interstate once that had this happen to her. From what I could tell, she did a pretty good job of getting to the shoulder. I remember thinking how much it had to suck. Glad you're ok, and good luck with getting it fixed.
AZ Community Team
Received 7,771 Likes
Wow! Nasty. Good thing you're OK.
Tire shops typically do one of two things - forget to tighten the lugs or WAY over-tighten them. Neither is good for you.
Better to double check them.
It happened on the highway. It was a small six lane highway with 3 lanes for each way. Losing my drivers side front wheel caused my car to go to the right I think or maybe I turned the wheel a bit, i dont remember. My car sat in the far right lane and I put on my hazards, there was no shoulder so I backed up plenty of traffic for a hour.
CTS-V Import Slayer
Ok...playing devils advocate here....cause it sounds like they are taking care of you and you are likely lucky they are.
You stated NEW WHEELS INSTALLED 10 DAYS AGO. Did you take them back into the tire shop to have the lugs rechecked after 100 miles like most shops note on the receipt? They say that this sometimes/often happens on new rims when first installed. I think it has something to do with the finish on the wheels or something when they are new before they get scuffed from lug use right at the lug nut contact area. I have noticed this notation on receipts several times after picking up my car from tire shops after new rim installs....almost sounds like they didnt note it on your receipt so they screwed up and left themselves open.
CTS-V Import Slayer
Here is an interesting theory.....kind of goes along with my theory above...
Powder coating and nuts......
http://www.type2.com/archive/type2/099161.html
http://www.type2.com/archive/type2/098298.html
http://www.type2.com/archive/type2/152342.html
I can just imagine some good ole' boy driving his POS Chevy with vintage tires laughing at you and your rice burner.. that happened to me once while filling up my Aunt's BMW. I opened the Gas Lid and the effin thing fell off. Two good 'ole boys filling up in their Chevy truck laughed their asses off.. The damn lid was attached by a plastic hinge that cost $100.. right there and then I swore to never buy BMW (bust my wallet).
CTS-V Import Slayer
More info on the same...
http://www.evansauto.procarcare.com/...dia_wheels.asp
When installing new wheels you should re-torque the wheel lugs after driving for 50 miles or so, in case the clamping load has changed. This occurs because of metal compression/elongation and heat stress. You will also verify the accuracy of the original installation. Be sure to wait for the wheels to cool down to ambient temperature before rechecking the torque value (Do NOT torque the lugs while the wheels are hot). Loosen and retighten to value, in sequence - simply repeat the same torque procedures as described here.
Did it strip the threads off the remaing studs?
One of the reasons for the retorque after a week or 50 miles is that the alloy wheels can expand/contract with initial temperature changes and settle in around the hub and nuts and occasionally create a loose condition.
but usually this happens slowly and you will feel vibration long before it comes off..
If the threads are stripped its more likely they were drastically over torqued and resulted in stress failure of one stud first then the threads on the remainder.
JMHO
JMHO
Backed up traffic in hickville, I was in tomball on 249 where they ride around in their trucks with a shotgun rack.
That was an interesting read Michael Benz.
The tire shop just put on RJ's Inspyres liquid graphite. Man i am so lucky that wheel is not messed up, there was not a scratch on it and it literally bounced and rolled about a quarter of a mile.
CTS-V Import Slayer
I will be getting my lugs checked frequently from now on. I was very lucky, because the freeway was about to open up to six lanes going each way and i would of stepped on it to 85 mph with ease, that would of been nasty if this would of happened at 85.
