MTF Sensor? Or not?
Old Jul 21, 2006 | 12:25 PM
DeadLock's Avatar
Forced Induction
MTF Sensor? Or not?
So I needed some warranty work done, had a clicking noise which is coming from the axles according to some other members on this forum, and needed a new LED center brake light, and replaced the clutch pedal (clicking)
So I thought if the techs are going to do the axles, I might as well have them do the tranny MTF, so I asked the service rep if they would do it, and I would pay the difference, since everything was covered under warantee and I was asking them to do some more work.
They called me back, telling me that there is some sensor in the tranny, which is connected to the MID, and the only way to reset the MID from prompting to change the MTF is to change it, so I would have to change it twice or more than necessary if I had them do it.
I call BS, and I know a lot of people get the GM synchromesh and claim it does wonders.........I dont have any shifting or tranny problems, but I figured if the axle will be off, they might as well.
Some good info about the GM MTF can also be found here
So my queation I guess is, is the MID somehow connected to the MTF as well as motor oil?
Old Jul 21, 2006 | 04:25 PM
SouthernBoy's Avatar
Registered Member
News to me.
Old Jul 21, 2006 | 04:26 PM
Registered Member
News to me. I drained and filled my '04 manual tranny fluid with GM Synchromesh Friction Modified in the spring of last year. No MID resetting involved then.
Old Jul 21, 2006 | 04:52 PM
Ron A's Avatar
Administrator
The code for the transmission fluid change is a 3, and under normal conditions it probably won't show up until you have driven 100,000 miles. The manual doesn't specify if this is auto or MT so I guess it is the same for both, but when it does show up, you can reset the MID just like you do for any other service reminder.
It's possible, but I don't think there is any sensor in there. It will compute just like it does for everything else, using miles driven as the major criteria.
So, I agree with the BS claim.
Old Jul 22, 2006 | 12:45 AM
DeadLock's Avatar
Forced Induction
Ok thanks guys, I will just do the synchro stuff from GM myself, I think they just didnt want to do the extra labor............I am having too many problems with the dealership not FIXING things as they should........
RobbDizzle
Oct 15, 2015 11:16 AM
samson_420
Oct 8, 2015 01:47 AM
thegipper
Sep 28, 2015 01:01 PM
hrothgar02
Sep 28, 2015 11:08 AM
prbori
Sep 27, 2015 01:37 AM
