More Headliner Fun - I thought it could never happen to me!
Well it finally happened, after 7K miles the headliner came unstuck. I was ready to epoxy the thing back on, but my dealer assured me they had an Acura approved fix.
Well, the Acura approved fix lasted 1 hour and 29 minutes after I left the service dept.
Turns out, they just put new velcro stick tape back on the 5 sections and stuck it back on. So after a few bumps, it just came down again.
Well that night, I mixed up a batch of epoxy, that was so strong it burned a hole in two hard plastic containers before I was able to smear it on the velcro squares.
24 hours later, when I pull on the headliner, I can practically see me pulling the headliner down from outside the car it's so strong....so I figure, the whole roof will cave in on me before the headliner comes off again......but we'll see
![Ecstatic](https://acurazine.com/forums/images/smilies/ecstatic.gif)
Team NightHawk VP
haha, u better hope the epoxy doesnt eat through the roof lol
in all seriousness though, if you leave the car in the sun all the time it might come undone
Head a da Family
24 hours later, when I pull on the headliner, I can practically see me pulling the headliner down from outside the car it's so strong....so I figure, the whole roof will cave in on me before the headliner comes off again......but we'll see![Ecstatic](https://acurazine.com/forums/images/smilies/ecstatic.gif)
I'd be back at the dealer faster than you could say "Velcro".
Going back to the dealer?????? N-O-T!!!!
What good would that do??? We already know that their approved fix is nothing more than reapplying the same velcro/epoxy that failed in the first place. Another person on this board took that advice (going back to the dealer), and ended up without his car for 24hours and the headliner failed just the same the very next day. Do what everyone else has for the same problem, use a super epoxy that dried hard, not rubbery - then wait 24-48 hours before reattaching the velcro/headliner to it. Mine has lasted for 5 months and still going strong. Best part is, the car was in MY garage during the fix, not THEIRS.
Though the velcro may seem cheap its the easiest way for the liner to be removable. If clips were used those would unglue too. With the advent of headliner airbags these minor annoyances will be around till they figure out a foolproof system to keep the thing in place but still allow the fireworks to deploy.
Team Anthracite Member
they should have just designed the upper metal bracket with the same cutouts/clip holders as the headliner itself. This would have prevented the whole headliner mess.
No worries here....My magnets are still doing their thing
![Butt Head](https://acurazine.com/forums/images/smilies/butthead.gif)
My dealer had a quick effective fix... they put a spacer and then glue. The headliner had too much tension and the spacer provides a little relief. Also, to avoid the question... no there is no gap between the sunroof and the headliner.
what is the spacer made of? Plastic?
My Headliner seems like there is space between the roof and the headlinerf...but I am not sure if it has come off...when you'lls comes off, does it like completely fall off or there is alot more space between it and the roof or how do you know? Is it very obvious???
Any Pics of it coming off would be appreciated...
I JUST want to make sure before I take it to the dealership....
Thanks.
![Dunno](https://acurazine.com/forums/images/smilies/dunno.gif)
Thanks.
04 A-TL 6MT SSM/E N/Navi
What's your vin#? my is 01532X
Thanks.
Thanks.
The easiest way to check this out is to open the moonroof completely, then look into the opening. There are three sets of velcro holding the headliner to a metal bar running across the roof from door to door.
What usually happens is that the top piece of velcro will come loose from the metal bar, allowing the headliner to sag. It is not a big gap, but enough to see if you are looking for it, and some are worse than others, depending on how many pieces of velcro came loose.
When all the pieces of velcro are stuck to the metal bar, you will not see any space between the headliner and the bar and you will not see the white part of the velcro, which is the glue, which has separated from the metal bar.
