Missing door part
Old Aug 17, 2016 | 04:27 PM
kkauffman's Avatar
Missing door part
I have a 2005 TL in gray. Today I noticed this cover was missing off of my left rear door handle.
Does anyone happen to know how/where to obtain a replacement and/or a part number for it? MUCH obliged!
Missing door cover piece
Old Aug 17, 2016 | 05:04 PM
GOOSEej's Avatar
http://www.acuraoemparts.com/acura/tl/72644sepa01zf/2005-year/base-navigation-trim/5-speed-automatic-engine/body-air-conditioning-cat/front-door-locks-outer-handle-scat/?part_name=cover-r-rr-nh643m-anthracite-metallic
http://www.acuraoemparts.com/auto-parts/2005/acura/tl/base-navigation-trim/5-speed-automatic-engine/body-air-conditioning-cat/front-door-locks-outer-handle-scat
Old Aug 17, 2016 | 05:19 PM
kkauffman's Avatar
Thanks!
Old Aug 18, 2016 | 06:32 AM
Adobeman's Avatar
The DVD-A Script Guy
I think GOOSEej accidentally gave you links to the front door parts. Make sure you get the parts for the left rear door in your case
Also - I'm pretty sure that it will also come with the metal piece in you picture that is still attached to the door. You shouldn't have to replace the part still attached to your door. All you should have to do is carefully remove the new plastic shell from the metal holder and then clip it to the holder still on the car. Just be careful with the little tabs on the painted plastic part.
Old Aug 18, 2016 | 09:45 AM
kkauffman's Avatar
Thank you...I actually did the research and made sure I got the left side ...and I'm relieved to hear that I had have to rip my door apart to mount that plate!!! Thanks
Old Jan 17, 2017 | 03:53 PM
silental's Avatar
I just ordered my SECOND right front passenger side cap for my '05 TL. Yep...it just snaps on to the existing metal part in the photo which I do believe it comes with...but can easily be removed. I'm thinking of adding some superglue to the new one before I attach it.
The first one lasted 10 years. The replacement for that one a little over a year.
$15.95 on Amazon: https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
omgitsspooky
Apr 8, 2018 07:37 PM
rcchurro89
Jan 16, 2018 09:32 PM
202009
Jan 23, 2016 10:02 PM
