Mirror rolls down when reverse - TL06
Guys, when I put the gear in reverse, if the mirror control switch is on L or R, that mirror will turn down. However, if the switch is at middle position, nothing happens. Is it normal for an 06?
My friend has an 03 3.2TL and both mirrors roll down when the gear is in reverse
what's funny is I was going to post a question.......WTF IS WITH THIS?!?! my switch is in the middle and it doesn't roll the mirror down while in reverse but now after reading this thread, if the switch is in L or R, then that specific mirror rolls down?
wtf? What were the 'Ac designers thinking on this one? can someone rationalize this for me?
I have an 06TL
I have an 06TL
I have an 06TL
I have an 06TL
Jason
I have an 06TL
I have an 06TL
I'm sure the designers gave it a lot of thought
Originally Posted by leedogg
this way you have the ability to control the left side going down or the right side going down or no side going down. Imagine you're parrallel parking back into a spot, you need the right one down to see the curb but the left side up to see traffic behind you or oncoming or the vehicle in back of you as you pull in.
gurney
Originally Posted by HiTEC
All covered in the little book they give you when you buy the car. I think they call it a owners manual or something.
To the original poster, one cool thing about the 3G is let's say you are backing into a parking space and have the right side mirror set to tilt down. Midway through your approach on the parking space, you can flip the mirror control switch to the left mirror, so that you can make sure you are parked between the lines (I like to be fair to other motorists whom might want to park in the space beside me). I have my side view mirrors adjusted to reduce blind spots while driving, so I can't see the side of my car through them. Therefore, I have found this technique of switching the mirror tilt-down to be very useful.
The tilting of the mirrors was always a habit of mines, even in my previous cars. Just had to do it myself, for whichever side. This is a good convenience, just doesn't make sense to have both mirrors tilt down. You need the mirror to see how close your getting to the car behind you and your surroundings.
Personally, I would prefer if both mirrors tilted down...that way, it's easier to center the car while backing into a parking space. I rarely do this when it would matter, but for the few times I do, it would nice not to have to switch L, R, L, R and/or stick my head out the window. It would also help those who back into spots in between cars that obviously can't see what they're doing as they end up on top of one car and a mile from the other one.
That is asking for trouble. I can so see some moron, using that for parrallel parking or just ordinary backing up and likely backing into a vehicle or somebody and perhaps suing acura because the mirrors all went down and they didnt know how to change it.
I think this was discussed WAYYY back.. And it made sense.
Look at this senario:
If you are driving, then decide to parallel park. You will:
1. Drive up enough past your spot so that you could go reverse into it.
2. Place the the switch to R so that the right mirror goes down.
3. Once you are going reverse, you need to watch out for traffic comming behind you or passing you by, therefore you need the LEFT mirror looking straight back, not down.
It serves the purpose of you not hitting the curb nor hitting other cars passing you by.
It makes sense to me. Hope it helps.
1) Avoid parallel parking.
2) If you must, park on the end or pull through so you're basically just lining up along the curb while going straight.
Don't really follow step 3...if I want to look back to the left, I'll turn and glance. Around here, most people will wait until you back in and are out of the way before trying to drive past; therefore, there's not much to really look back to the left for anyway.
Regardless, it would still be useful to have both go down at the same time.
I have an 06TL
I have an 06TL
please tell me this is a joke???????
Dead serious...this isn't New York, you don't have to parallel park here...plenty of parking with no chance of scraping your rims. Actually, I find people who do it annoying (when they are in the process of doing it) as I have wait on them to get out of the way for me to proceed. That and it takes more effort and/or steps to do it...I just don't understand why anyone would want to do something that takes more effort to do (and this applies to everything in life, no just parking your car).
I owned a 2G TL Type-S and the passenger only mirror went down when in reverse. I dont know how your buddies mirriors both rolled down, that must be a factory freak.
Just noticed something really cool about the TL
Let me start by saying that I usually keep my right mirror in tilt down mode. This morning I was running late for work so I was in a little bit of a hurry. As I was backing out of the driveway I noticed that when I hit a certain speed the mirror tilted back to normal untill I slowed down again. I thought I was seeing things, so when I got to work I went to that back empty part of the parking lot, put it reverse and tried it again. It seems to tilt back to normal at around 15mph then it tilts back down to reverse mode when the car hits a sane logical reverse speed. I just thought this was pretty cool and wanted to share with everyone.
FYI.....I just had my drivers side mirror replaced because the motor was faulty. About a week ago, I noticed when I put it in reverse the mirror made a horrible popping sound. I took the car in two days ago and found out I needed a new mirror. Come to find out there was an internal problem with the motor. The dealer gave me a new mirror assembly.
Originally Posted by carguyrob
It is very useful when parallel parking (when set on the R). You can get close to the curb, but never touch it.
Funny thing about the mirror tilt-down is that I find it more useful when I want to parallel park in an unusually large space (say, a car length and a half). Did that just last night, actually. I find that a large space robs me of my usual reference points as to the car behind me as I back in, so the tilt-down mirror is useful to aid in spotting the curb in those situations. Otherwise, in a standard parallel park, it's not a feature I particularly need.
I use it all the time and I wouldn't want it to work any differently than it already does. When I back down my driveway, I check the right side with the mirror because there are some larger rocks near the corner of the driveway that sometimes get bumped into my path. I can see them as I back down and make sure they're where they belong.
And I'm glad Acura didn't omit them just because there are regions of this country where people don't need to parallel park.
ITSJESTER
17
12-06-2018 02:29 AM
soupi
14
11-15-2015 11:15 AM
