MID: What do you display?
#42
Originally Posted by datmrman
#45
Originally Posted by FAST4DR
Whatever retarted engineer decided on the menus for the MID was on crack.
1. The temp should be in the center console displayed all the time next to the clock.
2. There shouldn't be any titles to the info, just flip through the info.
3. Distance to empty should be separate with the gas gauge or at least on the same screen as the rest of the info.
I alternate between Odo/Temp and Trip Comp, depending on length of drive.
#46
Trip and outside temp. Does any one else notice that the temp reads very high? Mine must be off by 5 degrees or so.
I forgot about the trip computer in nav. I am going to give it a shot. Hope I don't juice the nav. I think the trip computer is worth whatever might be lost. I only occasionally use voice commads.
#47
The Boss
Originally Posted by Andrew McCarthy
I usually show the temperature with the trip miles which I reset when feuling. When I get above 300 I fill up.
#53
#57
Originally Posted by JAB00
Trip A & Temp.
I'm sure it's in the manual but figure might as well ask while I'm on the board but how does one reset the trip computer?
#58
Originally Posted by Actuary
trip comp or temp. rarely I active HFL (go to HFL and hit select) to see signal strength in various areas.
ITSJESTER
17
12-06-2018 02:29 AM
