Memory seat switch problem
Old Oct 28, 2007 | 09:44 PM
draztic1011's Avatar
I have a problem with my memory seat switch. They do not function. The backlights turn on with the other lights, however the buttons dont function. When pressed they don't beep nor do the LEDs in them light up. Any idea what it could be? What fuse controls that switch so i can see if its blown?
Old Oct 28, 2007 | 09:50 PM
timmahh's Avatar
it's me, Alan Rickman.
if you push them while the car is on i believe they will not do anything; ie while moving you can program them but you cannot have them move.
Press memo then press one or two - if the LED turns on they might be ok..
Old Oct 28, 2007 | 10:07 PM
they dont light up when i do so. Only the backlight works
Old Oct 28, 2007 | 11:49 PM
mn2trance's Avatar
All About Trance
Is your parking brake up or down when you're pressing this? If it's down, your memory button will not remember your setting.
Old Oct 29, 2007 | 12:47 AM
RSA_Secure's Avatar
FIGHTING ILLINI
what exactly do you mean by "Only the backlight works"
Old Oct 29, 2007 | 08:22 AM
rbf351's Avatar
Registered User
it means exactly what he said two times.
when he turns his headlights on the lighting aka blacklighting works.
Old Oct 29, 2007 | 06:57 PM
so does anyone know what it could be? If the backlight is on, then the switch should be pluggeg in. Could be a fuse? Are there any wires to look for beneath the seat?
Old Oct 30, 2007 | 12:25 AM
RSA_Secure's Avatar
FIGHTING ILLINI
^ it might be faulty memory module...04s have that problem If it's still under warranty take it to the dealer.
Old Sep 24, 2008 | 07:57 PM
can anyone else confirm that its the memory module? how would i kno if its the switch itself?
Old Sep 25, 2008 | 10:54 AM
xen-cuts's Avatar
ROFLCOPTER!
Mine have never worked.
Old Sep 25, 2008 | 11:46 AM
adesilva's Avatar
I have the same problem with my memory, it always forgets. Is there somewhere i can obtain this memory module for a cheaper cost? How much does it cost with acura if i get if fixed?
Old Sep 25, 2008 | 01:07 PM
ggesq's Avatar
Maybe these can help?
http://www.in.honda.com/Rjanisis/pubs/SB/B04-005.PDF
http://www.in.honda.com/Rjanisis/pubs/SB/B05-033.PDF
rockyboy
Aug 4, 2024 10:35 AM
Feb 25, 2020 09:57 AM
Fandango12
1/2G MDX (2001-2013)
Sep 20, 2015 05:25 PM
HeloDown
Sep 8, 2015 06:51 PM
