Manual transmissions
Old Feb 1, 2019 | 09:16 AM
Jbtech83's Avatar
I've got a 04 acura tl speed with the third gear grind. I'm getting ready to put a new clutch and flywheel in it and was going to replace the transmission also. Question I'm asking is, are 04 to 08 manuals all the same, and will a 07 to 08 type s manual transmission work on my car?
any advice on this would be extremely helpfully
Old Feb 1, 2019 | 09:22 AM
horseshoez's Avatar
Latent car nut
W-A-I-T! Before you do anything else buy three quarts of the following gear lube and put it in your transmission:Notes:
  • Make sure you buy the ACDelco Synchromesh Friction Modified version; they also make a non-FM version which is useless in our transmissions.
  • If you do a search here you will discover roughly 90% of the folks who have complained about 3rd gear grinding and/or pop-out issues have had said issues solved immediately upon replacing the MTF.
  • To answer your question, yes, all of the 3G TL manual transmissions are the same, however, the bellhousings are not.
Old Feb 1, 2019 | 09:24 AM
90foxnotch's Avatar
I believe 07-08 bellhousing is different. First off have you tried switching your transmission fluid to the GM syncromesh fluid? And also why not just rebuild your transmission? A lot of transmission rebuilders can rebuild a manual with ease compared to an auto
Old Feb 1, 2019 | 09:25 AM
90foxnotch's Avatar
Thumbs up
Beat me to it!
Old Feb 1, 2019 | 09:28 AM
Jbtech83's Avatar
I've already done the fluid change right after I bought the car. Hence the reason I'm going to put new transmission in car. Can I use my bellhousing on the newer transmission?
Old Feb 1, 2019 | 09:30 AM
Jbtech83's Avatar
Because I can get a used transmission for alot cheaper than rebuilding it and repairing it
Old Feb 1, 2019 | 09:43 AM
teh CL's Avatar
Yup, just swap yours over and your good to go.
I'm sure there's cheaper non Type S 6spds available.
Old Feb 1, 2019 | 09:48 AM
Jbtech83's Avatar
Cool that's what I needed to know. Thanks and I know there are lol I'm just keeping my options open when looking.
princelybug
Apr 29, 2025 08:51 AM
InWI
Feb 6, 2010 11:53 AM
StonedCL
Aug 29, 2009 09:58 PM
nokiaman
Nov 27, 2007 04:29 PM
danmcgraw
Dec 19, 2006 09:47 PM
