manual transmission refill, do you just fill it till it overflows?
So my previous MT fluid changes I just refilled it till it overflowed. Most honda MTs stated about 2.4 or 2.5 quarts. It'd start overflowing at probably 2.25 quarts (I assume because not all was flushed out). Is the 3g TL MT similar in the sense that you just fill it till it overflows?
On this 6MT, there is a tiny little check bolt that you remove. Then you fill the case with MTF (car on level ground) through the upper fill hole until oil starts to dribble out of the service port.
It's all spelled out in your owners manual...
Be sure to replace the washer on the drain bolt. The fill & check bolts aren't as important to replace the seal washer...
A drain and fill takes 2.3 U.S. quarts which is 2 quarts, 10 ounces rounded. Make sure your transmission is level by using a carpenter's level. I highly recommend not removing the check (sight) plug to do this. The reason is that it is small and only takes 8.7 ft/lbs of torque. Several people on this site have managed to wrench the head of this bolt off, probably because they didn't use a torque wrench. The drain and fill plug require 29 and 33 ft/lbs respectively. Use new aluminum washers and a torque wrench. If you fill with 2 quarts 10 ounces, you'll be fine.
When your engine's running and the clutch is engaged, gears and shafts are turning in your transmission so fluid is being stirred up and spread to all of the parts, even if your tranny's in neutral. Everything in there is getting an oil bath.
cycdaniel
Dec 17, 2019 10:58 AM
