Maintenance Question.
Old Dec 20, 2011 | 08:57 AM
habeebster123's Avatar
I just hit 100k on my 07 TL-S. I changed my oil and brakes regularly and changed the air filter once. I havent changed anything else (spark plugs, transmission oil, etc).
Do I need to do any maintenance or am I ok for now?
Old Dec 20, 2011 | 09:02 AM
there is a major service coming up.
at about 105k miles, a warning will pop up on your MID.
this is a timing belt and water pump service. it needs to be done.
I would replace the auto tranny fluid
Old Dec 20, 2011 | 01:56 PM
Bearcat94's Avatar
AZ Community Team
Good time for plugs, engine air filter, cabin air filter and Power Steering and Brake Fluids too.
Old Dec 20, 2011 | 09:18 PM
Hammer5312's Avatar
Drive it like its Stolen
So speaking of timing belt being changed....is the engine in the 08 an "interference" engine or "non-interference" design?
Anyone know....
by "interference", I mean that if the belt breaks while it's running then whichever of the valves that happens to open stay open and then the corresponding piston on its up stroke will run into that valve, causing catastrophic damage....
Old Dec 20, 2011 | 09:38 PM
Hi speed's Avatar
runnin a little boost
Interference. Break the belt, bend some valves.
kleenc2000's Avatar
When do you replace the transmission itself?
Old Dec 20, 2011 | 09:42 PM
xander569's Avatar
My First Acura
When it stops working.
Old Dec 20, 2011 | 09:58 PM
dragonsking91's Avatar
Go Pats!
ur car hit 100k and u never change the tranny fluid not even once??
Old Dec 20, 2011 | 10:29 PM
xander569's Avatar
My First Acura
I've heard of certain people I may or may not be related to putting over 200,000 miles on their cars without changing the tranny fluid
08_UA7_Gr33k
Feb 11, 2016 02:17 PM
LeVeL
Oct 18, 2015 04:19 PM
polish_pat
Sep 30, 2015 12:22 PM
08_UA7_Gr33k
Sep 27, 2015 01:56 PM
mellsonnj
Sep 24, 2015 04:42 PM
