maintenance minder
maintenance minder
All I want to do is change my oil sooner (3000 miles) than when the maintenance minder says to without knocking the system off. so I know when to do the other maintenance requirements. Can this be done without a problem? Please help
yes it can be done w/out a problem.
This may be more than you want to know, but here's the full procedure to reset the MID display, and also info at the bottom about other service reminders when you manually reset the MID yourself.
(The procedure on page 196 (of the 2004 owner's manual, and probably for later models also but if anyone has a later model with the correct procedure please let me know) of the manual is incorrect. In paragraph 3a of the manual, the requirement to hold the button for 10 seconds the second time it is pressed is omitted. If this is not done, the display will not reset.)
1. Turn the ignition switch to ON
2. Select Trip A or Trip B (You can use either one, so if you are using one to record data for something, use the other one to reset the Oil Life Indicator).
3. Press the < or > button repeatedly until the oil life is displayed.
4. Press and hold the Select/Reset button for 10 seconds. The Multi-Information Display will ask for a confirmation.
This will explain what happens to the other services items when you reset the MID before the service due message appears.
From the service manual, page 3-6: (NOTE: This information is not in the owners manual.
So this means if you change your oil before the 15% Service Due Soon is displayed, and you go to reset the display, if there are other items to be serviced, they will show up on the display, and if you clear the display the MID will take this to mean that you performed the required service.
To clear the display:
After you get that service screen hold the reset/select for another 10 seconds.
It will then ask you if you want to reset.
Press the reset/select or the YES button (I forget which), and the MID will be reset
The statement from the service manual is a little vague, and I think they meant to say that if other items require service, the message "Service Due Soon" will be displayed, since if there is nothing else requiring service there would be no need for the message.
There is an explanation of how the MID works in the Acura Service News for September 2005 http://www.in.honda.com/Rjanisis/pubs/SN/B050900.PDF
and more about how you will get additional reminders when resetting the MID before it reaches 15% in the Acura Service News for September 2006: http://www.in.honda.com/Rjanisis/pubs/SN/B060900.PDF
NOTE: If you are resetting the display when the oil life is more than 15%, the maintenance message "Service Due Soon" will be displayed. Make sure the maintenance items requiring service have been performed before resetting the display.
It won't knock the system off because all of the other maintenance items go strictly by miles, unlike the oil change which takes other factors into consideration.
Not that I'm doubting you. But are you sure ALL the other maintenance items go strictly by miles.
Acura should have separated the two functions (oil life vs everything else). I change the oil around 3k also and consqequently have NEVER seen any maintenance messages on my 07 or my 04 TL. Acura,...bad engineering ....
^^^ why get an 07 when your 04 had such "bad engineering?"
^^ oh i totally agree. but why criticize (robertmiller) Acura for having "bad engineering" Obviously, by getting an 07 it wasnt as "bad" otherwise he would have went elsewhere?
2005 Acura TL w/ Navi
good stuff to kno..il be changing out my oil soon also..mine says 70% il wait til it drops to about 50% and change it to syntheic oil w/ oil filter..and flush out the transmission as well..im around 27k on my 05..wana keep it running new and healty
~Da Nocturnal Cheetah~
Fairly certain. The first link I gave in the MID post seems to bear this out because it says it will adjust tire rotation depending on the miles at which the MID is reset, and also gives recommendations for the other items based on driving conditions, which I take to mean it doesn't consider these conditions for these items.
My first oil change light came on at 5800 miles with 15% oil life left. The code that came up was A1. I had the proper service done and the MID reset to 100% Then I got paranoid and decided to do my next service at 9000 miles. I think it said 50% oil life left. Before the mechanic changed the oil he reset the MID and checked for the code. Oddly it was B1. Can you explain this? I just rotated the tires 3000 miles ago with the oil change Is this right or a malfunction? Thanks for your help
That's what it meant in the service bulletin when it said if you had less miles than needed for a tire rotation when you reset it, it wouldn't tell you to do anything, and then it waited until you reset it again, and you were overdue, and then it told you.
The MID didn't know you rotated the tires, so it gave you a reminder, which was the B1, meaning oil change and tire rotation..
It's getting confusing. A1 is oil change and tire rotation. B1 is oil change & filter and inspection items etc. The MID didn't know I did a rotation when I did A1 ?
Today I changed my oil at about 32,000 miles in my '04.
The Minder said I was 109 miles overdue. It had been reminding me for about one week.
The code was A1.
To reset it, all I did was press and hold the reset button for 10 sec. Just once. Nothing else. Is that the way it was supposed to be done?
The code was A1.
The code was A1.
The code was A1.
Originally Posted by darksom1
No, you have to do it twice! See post #4 in this thread.
So, I was a little inaccruate in my first post, but I didn't have to press it for 10 sec the second time, it went back to 100% as soon as I pressed it the second time.
Well, I pressed and held it once, then it asked me to confirm. As soon as I pressed it again, it went back to 100%.
Thank you Ron A for those missing steps! I just spent half an hour with my dad trying to figure out how to reset the darn minder. WHEW!!!
acuratl26
04-23-2020 07:30 PM
08_UA7_Gr33k
02-11-2016 02:17 PM
08_UA7_Gr33k
09-27-2015 01:56 PM
