Maintenace schedule
Keep Right Except to Pass
Read the manual again, starting with page 193. In particular, focus on pages 195 to 199. Those will tell you all you need to know with ample specificity.
The car will tell you when a service is due. I don't exactly follow it beause it will take me past 10,000 miles on an oil change and I don't agree with Acura's interval on the ATF. It should be changed every 20K, not 60 or 120.
thanks for your reply----however, i have only 15,000 miles on my '04 tl------the manual will only tell me maintenance minder codes and not the actual number of miles for maintenance items-------i would like to know when things should be done for future reference-------thanks again
It sounds like you don't drive much. You should, at a minimum, change the oil and filter once a year if you're putting minimal mileage on the car.
Registered but harmless
Received 1,102 Likes
Brake fluid should be changed out every 3 years, regardless of mileage.
The transmission fluid should be changed @ 60K, then every 30K thereafter.
Given your usage, you might as well change the engine oil & filter every year and change the transmission fluid and engine coolant every 4-5 years, along with the air and cabin filters.
Adjust valves when noisy; change the timing belt at 105,000 miles, or 10 years for your car, maybe?
I looked at the tl-s type-------great car, but the new '09 looks even more awesome-----------my '04 has a manual transmission------------when should i change the fluid? My wife has an '04 tl with auto transmission---just went over 60,000 on her car--------i'll change her fluid asap---thanks for the assistance
I changed my MT fluid (to GMSFM) at 15K and 30K. Now I am at 48K and thinking next change will be around 55K (next Spring). I think SouthernBoy changed his MT fluid (to GMSFM) at 8K and then at 50K, and the fluid still looked good when he changed it out.
mugen_kid
11-13-2015 10:38 PM
