lower grill mod on 07 Type-S
hey guys i bought some extra lower grills for my 07 type-s to mod. i only did one side to see how it would look. i orderd some aluminum grill from grillguy.com. and cut it to fit using my dremil tool. it's not that cheap gutter grill stuff many people use. its powder coated black, and pretty thick.what do you think.
modded side
stock side
front
should i leave it stock? or do the whole thing. i also order the top front grill too. the plastic oem grill parts were cheap $15 for each lower grill and $9 for the top from del ray acura.
modded side
stock side
front
Kaa - Ching !!!
Location: Rhode Island.....Self-Proclaimed Chromed Cousin of Brettallica
Looks great - I love the honeycomb on the TLS so much so that it's all going on my 06. Nice clean work there JP going to try doing the big grill too?
Godfather of Chrome
Location: Santa Cruz, and yes I'm a hippie with retro 1970s sideburns and a chrome fetish
1 Post
Originally Posted by ATJ32
Stock looks better but what you did looks really nice........leaving it stock will look like everybody elses.....flip a coin. BTW nice work.
Then again, I give props to anyone who tries something different. It's all about what you like, since it is your car.
Oh, and I definitely don't think it looks bad...just to be clear.
I think it looks incredible! GREAT JOB!
So explain this for me...This is what I THINK you did...
You ordered an additional set of lower grille inserts, cut the plastic honeycomb out, mounted the metal honeycomb from behind, then replaced the entire piece.
And you're planning on doing the same thing to your upper grille as well.
Did I even come close to guessing right?
If so, did you have to remove the entire bumper to get the OEM insert off? Or were you able to get it out from under the car?
One more question... Is the metal honeycomb available in stainless as well as powdercoated black?
Let's Go Pens
Im in the process of working on my grille too. I didn't realize the lower pieces were so damn cheap. I'll order them and cut those up that way if I screw up (not an experienced dremel user) I don't ruin my stock ones
FizzyStatus!
Looks rele good! BUT-(this all depends on the price and time involved) it's not that much of a difference, especcially to the common eye/nonTL modder, dont know if it's really worrth it for the TLS.
Don't get me wrong though..I think it looks great. And if it's not too time consuming/expensive than it's a really good mod
If you changed the main grill, would it restrict the airflow? I think the modded side looks less open that the stock honeycomb.
By the way, I like the mod and I think you did a very neat installation.
DerrickW
11-15-2015 05:52 PM
