Locating a replacement starter for a '07/'08 6MT Type-S
So far, I'm having no luck finding a replacement starter for my 07 6MT type-s. I did some searching and it sounds like the majority of folks suggest avoiding going with an aftermarket starter from Advanced Auto or Autozone. Do ya'll have any tips on where I can find a starter for my vehicle?
It's kind of early for an 07/08 starter to go out, but not unheard of. Are you sure it's the starter?
I'm not sure where you are hearing that A-M starters are a bad choice....
Here's a link to a new starter, non-OEM:
STARTER 07 08 ACURA TL 3.2L 3.5L 31200-RDA-A01 31200-RDA-A02 MHG028 31200-RDA-A01 31200-RDA-A02 - Newegg.com
JJH (12-03-2014)
With that said, the manual type-s starter is different from the automatic tl, manual tl, and automatic tl type-s starters. So I don't think that the one that you linked will work. Thank you for looking though.
Any issue with simply buying an OEM starter online? Can be had for around $300.
Or maybe you can fix yours? If you know what's failing on it, then you can rebuild it or sometimes simply cleaning it is good.
Either way, full starter PN: 31200-RDB-A01
Check out the UA6 service manual for starter rebuilds. Most of this stuff is made to sound much more complicated than it is. Visual inspection and cleanup should tell you what's the issue usually.
EvilVirus (12-04-2014)
There is something wrong with it. I'm not just replacing it to replace it lol. I have had to resort to tapping it with a breaker a bar a few times to get my car to start.
JJH (12-03-2014)
I still don't understand why you would start it more because its a manual. What does it being a manual have anything to do with it?
If I had an automatic, I would just put it in park and run in to wherever I am going without turning the car off for those short stops.
Does that make sense?
the only time i did that is when my parking brake wasnt adjusted correctly, so the car rolled back when idling. I had to put it in first, and shut the car off, if I just wanted to wait in my car. this def. took LONGER than just idling.
the justification of it's easier doesnt make sense, because its def. easier to pull the parking brake while you idle.
So, is your parking brake adjusted correctly?
So locating these internal components for this starter is just as difficult as finding a starter itself.
Acura Parts @ AcuraOEMparts.com - Genuine Acura OEM Parts from Delray Acura
There is the starter itself along with the internal components, but no brushes. Unless the armature includes the brushes?
Here's what it shows for the starter part numbers:
001 06312-RDB-515RM STARTER, CORE ID (SM-44248) (06312-RDB-515) (RMD)
I take it that the RM/(RMD) means remanufactured?
No
Good luck. :-)
Zonian22
11-14-2015 01:20 PM
BlkTxAcuraTypeS
10-18-2015 08:05 PM
asahrts
09-04-2015 05:55 PM
