light beam
Originally Posted by IIHII-TL
my front headlight beams seam to be uneaven. the beams to no match up in the horizen? does any one else see this?
It is not a mis-alignment.. You will notice that they go up something like steps from left to right. This is to compensate for oncoming drivers from the opposite direction. So the right side has a higher lighting while the left side is a bit lower.... this is what i think is happening need some confirmation
Not due to alignment, but a "cut off" flap in the headlight. When you put on "high beam", that cut off flap lifts up and you get the full xeon power! Previous generation TL has a separate bulb for high beam.
mada51589
Jan 9, 2025 04:40 PM
prox
5G TLX Problems & Fixes
Sep 1, 2015 02:03 AM
