LED DRL Help!?
LED DRL Help!?
Alright so I'm quite confused as to what's happening with my DRLs..
I had LED DRLs in my old car but didn't bother installing the relay harness because I was fine with the DRL light that came on the dash, and they were still bright enough.
Now for my Acura..
The DRL light isn't even on my dash, and I have this going on :
This is a 68 SMD LED bulb, and less than 30 of them light up. Is a relay harness required in order to provide power to all 68? or are these just a bad set of LED lights?
Any help would be appreciated, thanks!
Now for my Acura..
i believe you need the harness so it can provide full power to the LEDs, because DRL's run the bulb at a certain lower percentage so it's not fully bright, so it's doing the same for the LEDs (running only a certain lower percentage of power)
Yes, you need the harness to fully power the LED DRL's. Here is a link to my write up on how to install the harness.
https://acurazine.com/forums/3g-tl-2004-2008-93/ijdmtoy-led-drl-harness-install-w-pics-853543/
LogicWavelength
3G TL Photograph Gallery
33
Nov 1, 2015 09:38 AM
blacktsxwagon
Oct 27, 2015 10:12 PM
