Krazy glue on paint
Old Aug 2, 2014 | 02:12 PM
Acura2005tl's Avatar
7th Gear
Thumbs up Krazy glue on paint
Does anyone know how to get crazy glue off from the exterior of the car? Any suggestions will be helpful it's only a few small drops. Thanks
Old Aug 2, 2014 | 02:45 PM
revolutn's Avatar
Nail Polish remover aka acetone will remove / break it down, but it will likely strip any wax, and I can't say what it's effect on the top clear coat will be, it shouldn't hurt the actual paint though.
Someone with more detailing experience might be able to comment on the clear coat or an alternative product.
Hope this helps some.
Rev
Old Aug 2, 2014 | 03:18 PM
i_TL's Avatar
08 TL
3M Adhesive Remover, remove almost any type of glue/adhesive, tar, etc, without harming your paint, I use it all the time....hope it helps..
Old Aug 2, 2014 | 03:32 PM
96SC4's Avatar
^^ +1
it also removes wax from plastic/rubber pieces on the exterior as well
Old Aug 2, 2014 | 04:05 PM
7th Gear
Thank you very much will deff go buy it
Old Aug 2, 2014 | 10:23 PM
anx1300c's Avatar
Goo-Gone, gasoline, 3M adhesive remover, acetone. Any of those will work without hurting the clearcoat. Just be sure to clean well and then wax the area afterward.
Old Aug 2, 2014 | 10:39 PM
CL-S progression 01's Avatar
lowrd on tein CS biatch
If those methods above don't work. The superglue may be too thick.
You may also try using a clay bar. I have removed enamel paint that was one yr old off two peoples cars with just a lay bar and the spray it comes with.
But if all else fails...
Tape around the glue spot and slowly! Scrape off the glue with a sharp razor blade.
I did this to remove the acura gunk behind the emblems on the trunk on my CL. Took an hour but it all came off and not a scratch.
If the area is flat use a curved blade so u can focus on the glued area.
Only remove the glue/substance till there is just a bit left. How much a bit is? Is however close u are willing to go with the blade.
If by chance u do nick the clear u can polish it out if it's not deep. Or wet sand it then polish it.
Only use the razor blade tho if ur shit outta luck with the other options, cause obviously using a razor blade is risky,but it worked for me.
Either way it will come off.just don't get ancy and rush. That when stuff goes wrong.
Slow is fast
Old Aug 3, 2014 | 09:12 AM
TurnerDan's Avatar
winner winner. Also goo-gone.
Make sure you wax the area afterwords.
Jul 16, 2017 07:33 AM
detailersdomain
Wash & Wax
Oct 9, 2015 10:13 PM
jmaxima03
Sep 27, 2015 10:22 AM
spoiler900
Sep 23, 2015 04:41 PM
