Key Rattle-What do you do?
Old 05-25-2004 | 02:52 PM
Ken7's Avatar
I'm surprised nobody has commented on the rattle caused by the ignition key with the remote. When you're on a rough or wavy road, the key sways and the remote hits the plastic immediately below the ignition switch. I'm thinking of putting a small piece of foam to stop it. Anyone else?
Old 05-25-2004 | 03:17 PM
Tripp11's Avatar
Newbie for Life
I don't keep any other keys on my car ring specifically for this purpose.
Old 05-25-2004 | 04:07 PM
Ken7's Avatar
It's not other keys that are the problem (I only have the ignition key on the ring), it's the Acura remote that bangs against the plastic right below the ignition switch.
Old 05-25-2004 | 04:15 PM
Eduardo's Avatar
USC YQUE
Red face Acura's on top of the situation!
I've read that Acura USA has sent technical Service Manuals to all their service departments. It appears that there are more and more TL owners going to Acura service centers demanding this be corrected. The rattling caused by the key is apparently too much for TL owners. I think that they will have an update midweek. Just go to your local Acura service center!
Old 05-25-2004 | 04:21 PM
Ken7's Avatar
Good info Edwardo. I'm really surprised others haven't commented on this. It's REALLY lound when that puppy hits the plastic. I can't imagine what they'd do other then add foam to the immediate area around the ignition switch. Of course a one piece key/remote would have solved the problem entirely.
Old 05-25-2004 | 05:18 PM
NBP04TL4ME's Avatar
Stay Out Of the Left Lane
What you do suppose they are going to come up with as a solution? I have the same issue and thought it was too petty to complain about.
Old 05-25-2004 | 05:23 PM
Tripp11's Avatar
Newbie for Life
LOL - My fault...I thought you were complaining about other keys jingling around. As for just the remote banging against the steering column, IMO it sounds pretty petty to me. Plus it amazes me that tons of people are complaining about this to the point Acura is going to do something about it. Seems as if there would be "bigger fish to fry" than a remote that hits against the steering column like every other car known to man.
Old 05-25-2004 | 05:26 PM
NBP04TL4ME's Avatar
Agreed -
I'd prefer to see Acura spend time on other things -
All in one key/switchblade
Squeeky Brakes
Rusty Tail pipes.
Old 05-25-2004 | 06:14 PM
LeMasseHammer's Avatar
I got sick of this happening in my TSX, so I stuck a 1" long piece of weatherstripping tape where the key fob hits -- not pretty, but it works great. I guess the car was designed with the Accord key in mind, which is longer, and has no remote/fob to clang against the steering column.
BTW, this is the same weatherstripping tape I used to keep my license plate frame from clanging when I shut the trunk
Old 05-25-2004 | 06:25 PM
moeronn's Avatar
is learning to moonwalk i
Here are a couple of options that I am going to look into, though your options may vary depending on interior color.
1. Black electrical tape
2. Black foam tape
3. The soft side of Black velcro
Just a small piece of one of these should help reduce the noise. Seriously, it's not a huge issue, but Acura could easily spend the extra $.50 per customer on this. have something at the dealerships that people can pick up and install themselves of have it installed when other service is performed.
Old 05-25-2004 | 06:31 PM
6mtV6's Avatar
I6
Maybe if more ppl complained, Acura might come out with a integrated remote and key.
Old 05-25-2004 | 06:43 PM
Actually, I'm not a fan of the Accord key -- it's really big. Unless Acura came up with a switchblade/folding type, no thanks :toothless
Old 05-25-2004 | 06:47 PM
GunnmeTaLCURA04's Avatar
GÜNnµ ¡Ï
why dont you just put the radio on. Maybe if u are hearing music. u wont hear. i didnt even know this sounded. i have just key, with remote and a ring. no noise. never noticed, but i bet i will be on the look out for it. but still. WOW. how retarded. lol. i mean just opening the windows you hear more the other cars and all than a simple key swinging.
Old 05-25-2004 | 06:54 PM
boltjames's Avatar
Team Camel Executive VP
TLGator's going to fry your arse for having such a large problem in the context of what he does for a living, bub.
BJ
moeronn's Avatar
Have you ever gone over a speed bump? As I said, it's not a huge issue, but it is something that could easily, and cheaply, be remedied. I guess I am a retard, but at least I know my hearing is good. :p
Old 05-25-2004 | 06:56 PM
rets's Avatar
Moderator Alumnus
I'm not the big fan, either... these below are what I know out of Honda...
Old 05-25-2004 | 08:23 PM
Ken7's Avatar
Rets, yup, any one of those would have solved the issue. The funny thing is though, that the sound that the remote makes against the column is far louder than some of the other rattles in the car.
Um Gumme, unless your deaf, the sound is clearly heard with the radio on. Of course if your deaf, you might also be blasting your radio to the point that you won't hear the key rattle or any other rattle in the car.....of course you'll probably cause your sub to rattle in the process.
BJ, would Gator do that to me? That IS cause for concern!
Moeronn, I'm going to try one of those too. It should really be an easy fix....maybe just not too pretty.
Old 05-25-2004 | 09:03 PM
TLGator's Avatar
BJ
Hey BJ! Don't you DARE make fun like this! People DIE from key rubbing injuries every day!
Old 05-25-2004 | 11:19 PM
boltjames's Avatar
:bowdown: :lol1: :lol1:
Very good.
BJ
Old 05-25-2004 | 11:27 PM
-=¤willhaven¤=-'s Avatar
Team Anthracite
or you could get one of those detatchable key kind of chains. where you have your main set of keys for your house and your key fob, and then theres a detatchable bit where you can have another ring with your car key on it.
reach in the pocket for keys. detatch the car key and tap the unlock button and only take out the car key itself for the ignition.
its also much much harder to accidently leave your keys and fob in the car at the same time. if you accidently leave one behind... who gives a shit?
Old 05-26-2004 | 12:26 AM
apwalsh's Avatar
I think that was a joke - about Acura actually doing something about such a trivial thing.
Old 05-26-2004 | 09:08 AM
First of all, it is good to see BJ being a little sympathetic instead if his usual sarcastic self.
But the issue at hand is the blood curdlling sound of the darn remote colliding with the steering column. What I used to do was turn the radio up near max but then I learned I was damaging my hearing. Now, I just insert a few cotton balls in my ears before I place the car in drive. It works like a charm.
What's that? Can you hear me now?
Old 05-26-2004 | 11:07 AM
elessar's Avatar
Return of the Ring
Heh heh heh... wow, you guys are actually serious..... right? Sometimes it's hard to tell with this group. I thought it was weird that I never noticed this, since I have noticed a couple of other little rattles that have come & gone. Then I realized that it's probably because I keep so damn many keys on my keychain, that the key fob is actually shielded from the steering column by them! Seriously, you guys should try that. All you get is a little jingling of all the keys, which is easily drowned out by the radio (I never even notice it). Sometimes it pays to have a ridiculously cluttered keychain. Of course, this wouldn't work well for the guy who was complaining that the key fob itself is too big for his pocket! (Seriously, if you're not a chick, why the hell are your jeans that tight?!?) :lol2:
Old 05-26-2004 | 11:49 AM
Ron A's Avatar
Administrator
2. Black foam tape
Thanks for the hint. I cut a piece of black velcro about 1 1/2" square and put it on the steering column. Works good and is hardly noticeable.
Eduardo's Avatar
USC YQUE
Red face That's correct!
Yeah I was being sarcastic...though I wonder if anyone has gone and complained to Acura?
Old 05-26-2004 | 02:42 PM
Ken7's Avatar
I did, but I told them YOU told me to do it!
Old 05-26-2004 | 02:44 PM
GaleForce's Avatar
You touch my tra la la...
Its a key rattle get over it.
Old 05-26-2004 | 06:41 PM
Ken7's Avatar
Now c'mon GF, is that nice?
Old 05-26-2004 | 06:57 PM
moeronn's Avatar
If it doesn't bother you, then congratulations. You are not as easily annoyed as some of us. But then again, you are amused by boltjames, so there is no accounting for taste What do you care if the key rattle bothers others?
soupi
14
11-15-2015 12:15 PM
eastcoastguy
10-29-2015 04:00 PM
malvothegreat
09-29-2015 01:38 AM
LoneRonin
09-28-2015 10:11 AM
Sue1910
2G CL Problems & Fixes
09-27-2015 01:34 PM
Quick Reply: Key Rattle-What do you do?
