Just purchased '07 TL Type S
Old Mar 12, 2017 | 07:56 PM
Samsosep's Avatar
I just bought a Type S 2007 with 190,000 km
Is there any servicing I should look to get done for this much km?
Old Mar 12, 2017 | 11:16 PM
treal512's Avatar
timing belt, water pump, etc that you can get all in a kit (Gates, Aisin)
serpentine belt
transmission fluid (AT vs MT)
oil change
air intake filter
cabin filter
Unless of course they've already been done.
Old Mar 13, 2017 | 02:44 PM
nanxun's Avatar
Would check if the timing belt has been replaced. Recommended service at ~170,000 km (or 105,000 miles). If not, seriously consider having it done.
Old Mar 13, 2017 | 08:46 PM
jhb31's Avatar
If you have maintenance records then just go by the service indicator for what needs to be done. If not then definitely the timing belt/water pump, trans and oil. Brake fluid is supposed to be done every four years. I guess it must get dirty as I did mine myself after four years and five years after than when I was in for service the dealer told me the brake fluid should be changed and the dealership I go never tells me I need any additional work normally and had never mentioned the brake fluid before not even knowing I had changed it out the first time.
Good luck with the car. Best car I have owned. Other than the HFL module going which they all do and a power steering o-ring than was under a buck nothing out of the ordinary service/wear items since new and those two items took less than 30 mins combined to replace. Very easy car to work on as well. The dealership here only charges $39 for an oil change and I think the trans service was around $100. Most of the other stuff you can do yourself.
Old Mar 13, 2017 | 11:01 PM
Steven Bell's Avatar
Congrats and welcome to AcuraZine.
Old Mar 14, 2017 | 12:49 AM
Samsosep's Avatar
Awesome thanks for the replies. This car is a blast definitely want it to last me a good amount.
Old Mar 15, 2017 | 11:41 PM
Le7316's Avatar
Pix please
sockr1
51
Jun 24, 2022 02:07 PM
AdamWeston
Oct 20, 2019 09:33 AM
Platnm0705
May 24, 2017 03:19 PM
Type-S_215
Apr 3, 2017 07:46 AM
Ryan Travis
Feb 15, 2017 02:02 PM
