Installing Rear Aspec lip
Old May 21, 2008 | 07:57 AM
bzyrice's Avatar
Hey guys!
Installed the front lip and side skirts yesterday and it wasn't so bad! Only problem I had was with a bolt that wouldnt come out on the passenger side skirt.. I had to cut the head off of the screw.. but nothing I couldn't handle.
I have a question about installing the rear lip. Why do you have to drill holes into the rear lip? See install instructions #7 and #8:
http://photos.imageevent.com/astrobo...er_spoiler.pdf
Need this info ASAP since I will be doing this within the next few hours.
Thanks!
Old May 21, 2008 | 03:02 PM
enigmaos's Avatar
Too Fast TOO FURIOUS
to secure the sides. if you don't want to drill holes, then use 3m double sided tape?
Old May 21, 2008 | 03:45 PM
bzyrice's Avatar
well i didnt drill the holes.. I didnt see the point. There were 2 holes there already. Everything worke out fine. I am guessing the hole is there if you want to remove the bumper?
Old May 21, 2008 | 03:47 PM
bzyrice's Avatar
Here is how it turned out!
Old May 21, 2008 | 05:19 PM
pohljm's Avatar
Yes you are correct, you dont really need to drill that hole to do the install, but it does allow access to the screw holding the bracket to the car if you want to remove it later.
Old May 21, 2008 | 05:25 PM
joeybabyluvsu's Avatar
08 TL-S Kinetic Blue
what type of a spec rims? gun metal? looks sharp!
Old May 21, 2008 | 05:31 PM
enigmaos's Avatar
looking good! how dark is the tint?
Old May 21, 2008 | 09:50 PM
bzyrice's Avatar
hey thanks guys!
yah i figured it was only there if you want to remove the rear bumper.. either way u would need to remove the lip to get to the bottom bolt, so I just didnt drill it..
tint is what came with the car..
and yes custom darker gunmetal aspecs!
Feb 25, 2020 09:57 AM
HairyMonkey019
Apr 22, 2016 10:50 PM
HOWELLiNC
3G TL Photograph Gallery
24
Oct 8, 2015 03:15 PM
obsessedmotors
Sep 10, 2015 10:49 AM
