Installation of the rear wing...
Old Jul 28, 2006 | 01:03 PM
JLui83's Avatar
I saw the thread already from the 3M Garage about the instructions on how to install the rear wing.. I just wanted to get first hand experiences with any problems of the install people incountered. Or tips?
Old Jul 28, 2006 | 01:13 PM
RYAN97812's Avatar
8 second & 150 mph member
No problems with it, just use a good drill bit and do it in steps like the instructions say. After you drill the holes put some touch up paint around them so they dont rust (doesnt matter what color they are under the wing). Also dont over tighten the bolts for the brackets or the wing they just need to be snug. Everything get to you ok? Hope you like it.
Old Jul 28, 2006 | 01:20 PM
JLui83's Avatar
Thanks Ryan,
I actually haven't opened the box yet. I will open it tonight. EVerything should be fine. Thanks again man!
Old Jul 28, 2006 | 01:29 PM
ding069's Avatar
acura-cl.com OG
its easy, take your time, align the templates. remember measure twice, drill once.
Old Jul 28, 2006 | 01:33 PM
joed40's Avatar
05WDP Midlife crisis
Just like Norm Abrahms!
Old Jul 28, 2006 | 11:47 PM
Michael T's Avatar
I did the wing install as well. If your going to be installing new springs make sure you get the spring installation tool listed in the instructions. If you don't have it your life is going to suck when your installing those springs. I've read other posts and you can probably get one from your local Acura dealership. Mine would've loaned me one but I struggled and got them in. Other than than that the install is smooth, the templates suck and are off so be prepared to do some minor adjustments to the holes. Probably have a good metal file handy unless you want your wing position to be off a lot. Widening the holes using a drill is risky IMO.
Good Luck!
Old Jul 29, 2006 | 07:41 AM
RYAN97812's Avatar
Sent him the homemade tool i made for the rear springs, works perfect. I had no issues with the template being off, just has to be sure to centerpunch the decklid before drilling.
Old Jul 29, 2006 | 07:49 AM
jmbnova's Avatar
How may I help you.....?
We can make this install work....
Feb 25, 2020 09:57 AM
james357
Feb 13, 2016 02:37 PM
EE4Life
Sep 11, 2015 10:13 PM
