I'm a believer GM Synchromesh!
Ok so i finally couldnt take grinding third gear anymore so i found some synchromesh at a local buick dealer today and then went and swapped out the honda junk.....I was a lil skeptical but omg i couldnt believe the instaneous difference....i drove home roughly twenty miles and i would normally grind 3 to 10 times....My car shifts like butter now with no grinds ....its pretty amazing!
Registered Member
No, no, no. GMSFM fluid is for manual transmissions, NOT automatics. Don't even think about using this stuff in your automatic TL.
Heres a recap....had the magic juice put in on tuesday....i would normally grind or get locked out of third atleast a few times a day...Its now friday and i have not grinded or felt the slightest bit of resistance when shifting in any gear especially third...This magic juice ftw!
lowchief, did you just call all the GM dealerships around you until you found some? what is the part # and how much did you get??
i know i know i should search to find these answers
ya basically i first called my local cadillac dealer who directed me to my local buick dealer who had only 5 quarts sitting on the shelf....You only need three quarts....and there and $15.00 a piece...part number is #12377916 make sure its friction modified!
i think it took 2.5 quarts roughly.
The AC Delco part number is #10953509.
![](http://i218.photobucket.com/albums/cc253/KomodoTGC/DSC00792.jpg)
i
Here's the how to everyone: Looks straight forward.
https://acurazine.com/forums/3g-tl-2004-2008-93/%2A-6-spd-tranny-fluid-change-%2A-3g-garage-c-013-a-558814/
I have 3 bottles of the friction modified waiting to be put in. I can't wait!
Registered Member
Gentlemen;
A drain and fill takes 2.3 quarts (U.S.). That's two quarts, ten ounces rounded. Do NOT overfill.
Also, you do NOT need to remove a slew of stuff on the upper end. In fact, you don't need to remove anything at all if you have the proper tools to do the job. Not the battery or its plate, not the ribbed throttle body coupling, not the air cleaner upper housing cover.... nothing.
I was one of the members who did some extensive writeups on this procedure so you might want to search for those.
