I suck at searching - replacing parking light bulb
is learning to moonwalk i
I searched the forum and the 3G garage but couldn't find the information I was looking for. I need to replace the driver side front parking light on an '04 TL. Any information/links on bulb specs and/or DIY instructions are greatly appreciated.
At least now I know how to cut a hole behind my glove box to replace the cabin air filter and how to replace the side markers with LEDs
![Wink](https://acurazine.com/forums/images/smilies/wink.gif)
iWhine S/C 6MT TL
-Turn the wheel all the way to the right
-shut off car
-Look at the black Splash shield that runs along the front bumper (Along the side of front bumper to the inside of fender)
-Half way up the bumper (give or take) will be a clip that hold the splash shield to the side of the bumper.
-Use a very small flat head screw driver and pop the center of the clip away from the base of the clip.
-Use that same small screw driver and remove the clip. Then use the screw driver and gently pry back on the splash shield.
-When shield is back, shove your arm towards the headlight and feel for the parking/signal socket.
-Twist off socket
-Install new bulb
-Twist back on socket to headlight housing
-Put back splash shield
-Put back in clip, make sure it goes through the bumper part as well
-Go wash your hands
-shut off car
-Twist off socket
-Install new bulb
-Go wash your hands
^^ Thanks for the DIY info. Do you know the specs of the bulb or have a link to it?
Mods - can this info be added to the Garage (if it isn't already in there and I just missed it)?
wusty23jd
09-24-2015 11:41 AM
