I let my little brother drive my TL for a week.
Awesome to the Max
Okay, so I lent my little brother take my TL for a week...and now that I have it back...it feels like shit....
1.) I have this clicking noise in my clutch which I didn't have before. Is my clutch gone? Do I need to replace it? When I'm in neutral and I step on my clutch pedal it clicks and on the way up it clicks...
2.) Before I lent my brother my car, my gear box felt smooth and when I was in a gear and touch the stick, it wouldn't wiggle or anything, but now, when I'm in a gear and I touch the stick it wiggles and shakes and feels like there's a lot of space, it doesn't feel as stiff as it did before. (btw I know stiff and stick makes this thing sound :ghey
What can I do? I don't know about #1, but I think for number two might have happened because he might've grinded gears a couple times.
Help...thanks
Help...thanks
Awesome to the Max
Originally Posted by TerminaderTL
Take him out to the woodshed and teach him a lesson!!!
I actually blame myself..I should've taught him how to drive properly before letting him take my car for a week..
but seriously, any real advice?
Yikes...
Your description of things doesn't sound good.
I'd suggest you have the trans fluid changed ASAP, but that may only help a little.
I'm thinking you're going to find some schrapnel in the transmission from chipped gears and or synchros.
If it's feeling sloppy shifting and vibrating that may indicate some damage to the synchros.
The clicking you hear/feel (?) from clutch might be the switch that disengages the cruise when the clutch is depressed. If the clutch pedal was popped hard enough it might have damaged the switch.
You should have it looked at by the dealer and throw yourself on their mercy and hope they'll do repairs under warranty if it comes to that.
VTEC HoooA
Help...thanks
Help...thanks
One issue I do not experience is the shaking of the stick shift. For that you may want to beat him!
Originally Posted by Nodoze2004
I think this issue has less to do with your brother than you think. I have a 2004 with 7400 miles and my clutch recently started this clicking as well. I mentioned this to the service tech the last time I was in and he advised that there was a similar issue with the 2004 Accord manuals as well. The issue requires the entire master cylinder be ripped and replaced. I also for the first time had difficulty putting the car into first gear the other day as well.
i've had a hard time putting mine in 1st gear about 5 times (had car for 3mths now), what's up with that? and because of that, when i'm the first car at a light, i watch for the other traffic lights when they turn yellow so i readily put it in gear..
Use this opportunity to pour some Specialty Formulations MTL-P 75w-85 in the MT.
They have an excellent fluid that has worked very well in Honda/Acura appliactions.
The main advantage of the Specialty Formulations fluid is that its TBN is over 13, compared to just 4-5 for the Redline MTL.
This means that the TAN number will not rise to a point where the fluid becomes unusuable over longer periods (30-40K). The main disadvantage of the Redline MTL is that it rarely lasts longer than 20K, since the TAN number is often sky high by around the 20K mark, thus the fluid is no longer suitable for continued use.
I'm pretty sure that the TL's MT capacity is about 2.5 quarts. Order the 1 gallon container from Specialty Formulations for $28.95+shipping, so that will set you back around $44.
Its slightly more than Redline MTL (which is about $9-$10/quart), but it is well worth the extra for its extended life and super silky shifting.
Michael
Michael
so driving your TL was his first experience with driving stick??
a brave man you are.
Awesome to the Max
he actually practiced when he was in iraq...he got back like...3 weeks ago..so i figured he knew how to drive
lots of dupe posts going on
https://acurazine.com/forums/car-parts-sale-361/fs-all-my-mods-taking-early-dibs-now-113635/
Awesome to the Max
https://acurazine.com/forums/showthread.php?t=113635
It's cause I found out what was wrong...and I wanted to start a new thread for it...because I thought it would get more coverage with a new title...
Yeah, its STOCK!!!
Help...thanks
Help...thanks
Awesome to the Max
Originally Posted by dtpjigzer
same thing happened with my car when my brother drove my car! i have this clicking noise when releasing the clutch and steppin on it. the click is so loud, it can be heard with the music down. and i also can feel this hard click too when releasing it. i wonder whats going on with the clutch pedal???
I'm taking my car in tomorrow..I'll find out and post
OK, now I have two things to say. 1: Those hummers are designed to last 15 years under heavy operating conditions, which does not include being blown up, but rather exposed to some harsh sh-t. And after being in Iraq he deserves to get to ride around in a nice TL, I say hes earned it(that is if he was/is on our side)
VTEC HoooA
** We interrupt this veering thread to revert back to the original topic **
I just had the clutch master cylinder replaced on my clicking 6spd 04 TL, and it is smooth as silk again. There is a TSB for the 6spd Accord, which also applies to the TL (sorry don't have the number). My dealer was aware of this and replaced it at no cost.
Car has 7400 miles.
** We now return you to discussions about Hummer transmissions **
Car has 7400 miles.
Licking Platters Clean
Newbie
Are you referring to the TSB 2004 Honda Accord V6 3.0
M/T - CLutch pedal noise/Notchy feeling?
I called acura and they said that it is only for the accords not for the TL's
Any can update this? bc i also get a notchy feeling when i put the car in 1st gear as well....thx
TSB 02-002
TSB 02-002
VTEC HoooA
Originally Posted by JackSprat01
Can you get us this TSB number? I have the clicking clutch problem and they already replaced the cruise control switch. Mine only clicks in the afternoon, when it's warm? Odd...took them two trips to the dealer just to duplicate the problem.
The TSB according to the dealer applies only to the clicking noise (which is audible externally) and the notching in the clutch itself (not the shift gate).
I initially experienced on hot days as well (we get plenty here in FL) but then it started to occur each and every time I drove the car. The first time I brought it in, they sprayed WD40 on it!! I was like thanks
They replaced the MC 2 days later
Keep Right Except to Pass
rockyboy
12-06-2022 02:29 PM
IIDXholic
10-08-2015 07:53 AM
