How to replace the clock spring?
Old Feb 9, 2017 | 08:40 AM
TheyGotMawty's Avatar
My SRS light is on, and no steering wheel controls work. I'm 99% sure my clock spring is to blame. The part isn't that expensive, but I don't know if I can replace it myself, because working on a 3G is somewhat difficult. Does anyone know how to replace this part? I've done several searches, but I got no results for the 3G. Do I need to remove anything aside from the steering wheel? Will the airbag go off even if I've disconnected the battery? Am I better off just paying a mechanic?
​​​​Thanks for the help!
Old Feb 9, 2017 | 08:44 AM
All honda's are the same...
youtube Honda clock spring.
you'll want to disconnect battery then open up the steering wheel air bag thingy.
youtube it...
Honda clockspring install
Old Feb 9, 2017 | 08:45 AM
Thanks for the quick response!
Old Feb 9, 2017 | 08:46 AM
Old Feb 9, 2017 | 10:15 AM
Adobeman's Avatar
The DVD-A Script Guy
Here are the scans for cable reel replacement and airbag removal/replacement. Many people have stripped the two T30 torx bolts because there is a good deal of thread locker on them. Use a top quality torx bit and be very careful when you try to remove them.
Old Jan 26, 2020 | 11:34 AM
sccrxer's Avatar
Is it possible to recoil the clock spring? When I removed my steering wheel, the ribbon fell out of the housing and it doesn’t seem to re-coil properly. I have a feeling Acura broke it when they did the airbag recall work and then Jerry rigged it back together.
Old Jan 26, 2020 | 04:33 PM
sccrxer's Avatar
Never mind I managed to get it back together.
