How to remove trim panels?
I need to pull off the door handle and belt molding for the right rear door and was wondering the best way to do it? Any tricks? Whats the procedure?
Thanks in advance!
Thanks in advance!
behind the door lock latch theres 2 screws. under the door handle theres a hole 1 screw long screw driver.....and the side of the door the rubber piece that pushes the button down to activate the interior lights holds the panel on.... then u pull from the bottom the panel comes right off.....BECAREFUL DONT NOT PULL ON IT HARD Lift it up slightly above the lock keep the door panel up and reach behind the panel and disconnect the lock wire from the latch.....if u dont do this with patience u will have a nice time replacing that cable the plastic breaks very easily.....ive had my share of fun with it. good luck
Kaa - Ching !!!
Location: Rhode Island.....Self-Proclaimed Chromed Cousin of Brettallica
https://acurazine.com/forums/ramblings-12/trance-list-93985/
Here's one for you - pictures included.
Oakes
Wash & Wax
10-12-2015 11:17 AM
detailersdomain
Wash & Wax
10-09-2015 10:13 PM
STL TL-S
09-23-2015 08:52 PM
